30th May 2017, 06:27 PM
Cluster fail / odometer overclocking
Hi all,
I hope you are well. I am based in Nairobi, Kenya, recently bought a second hand Nissan Patrol 2004 TB45 (4.5 Liter Petrol). The odometer is overclocking, for example, 5km for every 1km travelled. I took it to my local mechanic who have diagnosed a cluster fail and quoted USD 2000 for a new cluster. Though from my google searches I can see this is quite a common problem / defect for Nissan Patrols with lots of different options out there to fix, from earthing, to correcting voltage sparks / fluctuations. I am not a mechanic or mechanically savvy enough to do these.
Basically wanted to check if anyone has had a similar problem and if there is a temporary or permanent fix to the issue? My concern is spending money on a new cluster and then the problem still continuing.
Thank you!
Mowgli
30th May 2017 06:27 PM
30th May 2017, 06:54 PM
Welcome to the forum mate
The Following User Says Thank You to Dhuck For This Useful Post:
30th May 2017, 07:00 PM
Thank you, how are things down under?
30th May 2017, 08:38 PM
Hi mate, sorry to hear about your situation, found it interesting..
Hope that you get it fixed asap. less the coin..!
cheers
The Following 2 Users Say Thank You to in4m3 For This Useful Post:
JackCollo (4th June 2017), mowgli (30th May 2017)
31st May 2017, 11:56 AM
G'day and welcome to the forum mate.
The Following User Says Thank You to 4bye4 For This Useful Post:
