Results 1 to 10 of 13
Thread: Fishing Rod storage?
    Aug 2010
    Adelaide - Northern Suburbs
    Hey All,
    Anyone got any advice about where to store our finishing rods? We're going camping for a week in Streaky Bay with some friends (from Adelaide). Driving out there across 2 days and back in 1 day.
    We have 4 fishing roads (1 surf, 2 normal and 1 kids) - and not sure what to do.
    We have 2 Rhino roof bars on the patrol, so thought about strapping the rods to the bars . . .any suggestions?
    2006 GU ST 3.0td manual. CTEK 250S Dual Battery - Ironman 65L Ice Cube - Pioneer AVH-3600DAB - Tough Dog Adj 45mm Shocks, springs and HD steering damper - Airtec Snorkel - King Brown 3" exhaust
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    I would put them in a Poly Pipe with Srew ends and strap that to your Rhino bars. That is if your Surf Road is in two pieces
  4. The Following User Says Thank You to Bob For This Useful Post:
    Finly Owner (19th April 2011)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by tracemul7 View Post
    Hey All,
    I use a 100 or 150mm PVC pipe with screw on ends and store the rods in. Tie the pipe to the bars.
    That way the rods are protected from the trees, ets
    ________________________
    ______ 2017 D-Max _______
  6. The Following User Says Thank You to Maxhead For This Useful Post:
  7. #4
    ACT
    Haha, Bob beat me to it.
  8. #5
    581 Post(s)
    Yep x 3, cant beat the PVC pipe!!!
  9. #6
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by NissPat View Post
    x4 and i use big hose clamps to fix to the roof rack you can get at bunnings or plumbing shop
  10. #7
    Feb 2011
    Brisvegas
    agree with the tube. I would put the rods in rod bags to stop the runners damaging the glass etc. I then lay out the rods tip to butt, with the butts protruding, and tie them together, in my case with neoprene rod wraps, but anything would do. Foam at each end of the rod tube, or old rag, and that's it.
    If flying with same arrangement, check the length limits and put a handle or similar on the tube to stop it rolling on the baggage system, or tape two together.
  11. The Following User Says Thank You to Silver For This Useful Post:
    Bob (19th April 2011)
  12. #8
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    X5 on the pvc pipe, has always worked a treat for me
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  13. #9
    Aug 2010
    adelaide
    x6 the tubes are great
    might sound stupid but dont forget to take the reels off i put them in old socks
    OH LEATHER IS NICE
  14. #10
    Beginner indigothecat's Avatar
    Feb 2011
    Greenmount
    Quote Originally Posted by Silver View Post
    I have a 100mm PVC as everyone mentioned here and agree with silver about padding the end of the tube. I have two beach rods broken down and wrapped in a winter bed sheet (the fluffy ones); one rod down roll next bit roll etc etc.
    I may be stating the obvious but Rhino have an aluminum bracket that holds these 100mm or 150mm, just got one to bolt on to non Rhino rack for $30 (Conduit Clamp Set (BC2) ).
    Good Luck.
    '01 GU now has roof rack and tow points, it's a start at least.
    The lessons learned the hard way really do make your heart race.
  15. The Following User Says Thank You to indigothecat For This Useful Post:
    Bob (20th April 2011)
