29th May 2017, 12:40 PM
What bolts to block off zd30 turbo water lines?
Morning,
I need some advice as to what bolts to block off the old coolant lines in the block of my zd30 2001,
29th May 2017 12:40 PM
29th May 2017, 12:45 PM
I think the hose is 5/16th or 8mm give one size
a try when its cooled down completely
29th May 2017, 01:58 PM
Thanks for the reply, but not quite what I was after..
I want to seal off the block as I am no longer needing the coolant lines to the turbo. Guess I'm after the specs of the banjo bolts that would normally hold the lines there
30th May 2017, 03:31 PM
I think your only option is to remove the banjo bolts and take them to a bolt shop for measurement.
