23rd May 2017, 01:50 PM
Starter motor?
Hey All,
Just wondering if anyone can confirm that the sound in the vid is my starter in the way out? Or what it may be?
http://www.dropbox.com/s/gdgw4awacbw...%2029.mov?dl=0
Thanks Mick
2007 GU ST-S 4.8 Patrol.
40mm heavy duty springs, Dual batteries,
140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
23rd May 2017 01:50 PM
23rd May 2017, 02:05 PM
Skitzyrex
Sounds like the gear is not retracting from the ring gear when it starts. Might be able to get it repaired if thats the case. I would look at it ASAP as it may chip the gears on the flywheel.
Tony
23rd May 2017, 02:14 PM
4bye4
Tony
Thanks Tony, wasn't actually sure if it was the starter motor. Thanks for your response.
23rd May 2017, 06:03 PM
Put a long screwdriver or metal rod into the engine bay, touching the starter motor and get somebody to crank while keeping the other
end of the rod to the ear. That way you can pin point the location of the noise better.
Also try tapping the start with the same long rod while cranking/starting the engine and see if the screeching noise gets worse or better.
The Following User Says Thank You to dom14 For This Useful Post:
Skitzyrex (23rd May 2017)
