Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: transfer case bumpin the aux fuel tank
    May 2017
    Hi guys,
    when I drive my dual fuel (unleaded & gas) Patrol GQ offroad or over bumps, I think the transfer case or the rear trailin arm is hitting the aux fuel tank, which makes a sound of a metal sheet popping in and out - which is really annoying.
    Is that a common problem for dual fuel Patrols?
    Can something break or suffer from it? How bad is it?
    And most important of course, can it be fixed somehow? (How much would it cost?)
    Thank you and cheers, Marius
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    2 Post(s)
    Have you had a look under neath the truck to see where it might be fouling on the tank.
    It might help to know what it's actually hitting on but I wouldn't say it's the transfer case.
    Let me know how you go
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
    Legendary happygu's Avatar
    2 Post(s)
    There are aftermarket bent upper trailing arms to clear 75 Litre Aux Tanks, so yours might be this problem. This is where I would be looking first.
    Could be your tail shaft fouling as well over bumps, I ve seen that happen a lot
  6. #5
    Jul 2016
    I have the same problem. I have been trying to work out what it is. Must check it out. Next time I put it in my shed.
  7. #6
    Legendary my third 256's Avatar
    Aug 2010
    adelaide
    hi and welcome to the forum a great mob of people here and a lot of very usefull information
    best wishes with your patrolling
    stephen
    Jump over to the intros and say g'day mate something we ask all members to do, cheers, you'll get a better response that way http://www.nissanpatrol.com.au/forum...-Introductions
    2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
    OH LEATHER IS NICE
  8. The Following User Says Thank You to my third 256 For This Useful Post:
    threedogs (26th May 2017)
  9. #7
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    Quote Originally Posted by m4r1u5 View Post
    Hi guys,
    Speaking from the experience crawling under mine(RB30 with long range tank behind the transfer case, next to the tail shaft).
    That's where the original auxiliary tank used to be, I think, and where the rear main tank used to be has the LPG tank now(dual fuel).
    So, I don't see how it's possible for the petrol tank to grind on transfer case.
    Tail shaft is pretty close to the tank(about a centimeter) in my case, but I still don't see how it's possible for the two to grind on each other, unless the tank has become loose, in which case it is dangerous.
    If you think it's auxiliary fuel tank that's getting hit by something, they you can most certainly see some marks on the tank.
    A good place to start fixing it.
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
  10. #8
    May 2017
    After I checked the problem another few days, I must say it feels like something is pushing in the fuel tank (maybe from inside or above) and it doesn't sound like something is really hitting the tank. (couldn't find any marks)
    Two major things I noticed:
    - If the tank is completely full the sound of the popping metal sheet doesn't come up. The less petrol is inside the tank, the more this noise comes up
    - If there is a person sitting in the back seat, the noise comes up more quickly.
    Any ideas with my new discoveries?
    Thank you and I will upload photos later.
  11. #9
    38 Post(s)
    Sounds like it's coming from inside the tank. I'm wondering whether the intank strainer/filter has dislodged and moving inside the tank, making that noise. Or the tank might have come loose?! Full tank means more weight and the tank may be not moving due to weight?!
    Either way, this is not something you wanna put off. Sooner you find out the reason, the better it will be for your health.
    I am not sure how to interpret that. My guess would be it isn't related to somebody sitting on the back seat.
    But having said that, anything's possible. If there are modifications to the tank where the holding bracket has a bolt going through the floor and then to the seat mount(which might have come loose).
    Yank the seat, tank, etc and find out what's causing it.
    Cheetah Outreach
  12. #10
    Ill still say the exhaust is hitting the cross member, pretty common fault.
    Chock the wheels get under and have a very good look with a torch
    I mean't to say the tail shaft hitting the cross memmber, marks should
    be very easy to see
