Results 1 to 6 of 6
Thread: Side steps with rear AC
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Has anyone had steel side steps or rock sliders installed where they have had a rear air con?
    ARB say on their website that the AC pipe work along the chassis rail prevent them from being installed. Anybody have experience with this?
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    472 Post(s)
    G'day Chubba, I'd imagine they are worried about the 'clamp' over chassis type mounting systems. I'm sure they could flex out the lines but may still rub back hard afterwards. My new Millweld sliders are outer side chassis tapped plate and welded on as per Mill's fitting pick below:
  4. The Following User Says Thank You to MB For This Useful Post:
    Chubba (18th May 2017)
    Are they actually legal, didnt think you could weld then bolt to the chassis
    Technically no. It's not legal to modify the chassis at all.
    Mine is the same as MB's and is the strongest way you can mount the sliders.
  7. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    Chubba (19th May 2017), Clunk (19th May 2017), MB (19th May 2017)
  8. #5
    472 Post(s)
    Hmmmmm......thanks guys, best I find a really nice engineer quick smart then :-( Mind you these slider welds look ten times better than the trucks 'certified' Chev conversion welds ;-)
  9. The Following User Says Thank You to MB For This Useful Post:
    Winnie (19th May 2017)
  10. #6
    Jul 2015
    Quote Originally Posted by Chubba View Post
    Yes mate sure have
    Mob at yatalla qld have the
    Very good quality and good prices
