Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Rear drawers
    Aug 2014
    Perth
    10 Post(s)
    I can't understand how they can make them that cheap, I paid 5 times that price for my Black Widow drawers.
    3 words
    Made in China
    and a few more for good measure bulk orders placed with the Chinese manufacturer
    49 Post(s)
    I got mine for $375, but no freebies. As for the install, pretty straight forward mate.
    Just be prepared for a long wait after you order.
  4. #13
    Nov 2010
    Getting a life...
    38 Post(s)
    And don't forget to remove the Jack before u Bolt in the side wings
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. #14
    49 Post(s)
    Or the 3rd row seat belts.
  6. The Following User Says Thank You to jay see For This Useful Post:
    katwoman (18th May 2017)
  7. #15
    Jan 2015
    Canberra
    I have a set in my GU and a mate has a set in his GQ. They are really good value for money but:
    * They weigh 85kgs which is seriously heavy
    * The drawers only slide out about 80% of the way, they use roller bearings instead of drawer style runners
    * The fridge slide only slides out about 80% of the way, and it can't be swapped to the right side
    * Buy yourself a cordless screwdriver, there are literally hundreds of screws to do up
    * They can be tricky fitting if you have a rear cargo barrier, consider getting some adhesive rubber strip to go between the drawers and the cargo barrier to prevent squeaking noises
    * Be careful when fitting, they have really sharp edges
    * The rear seat belts can be left in, the drawers go in around them. On the other hand, once fitted the seat belts are not much use
    * I trimmed the metal around the jack cover so I can still access it
    * FOLLOW THE INSTRUCTIONS CAREFULLY - I didn't and had to remove the tops to fit the drawer stoppers
    * Use loktite on the screws, they seem to come loose easily
    In spite of all the above, they are really good value for money
    WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
  8. The Following 2 Users Say Thank You to JME_GU For This Useful Post:
    GQtdauto (20th May 2017), katwoman (18th May 2017)
  9. #16
    Hardcore belzi82's Avatar
    Jul 2011
    Thanks everyone. I will go and have a closer look at the display stock.
    I have my rear electrics wired into where the wings go so will see if I can modify to enable me to still access this.
