17th May 2017, 02:51 PM
Whistle
Hi ive got an annoying whistle everytime i pull away and slow down i changed the manifold gasket last time it happened but its come back slightly different tune this time and ive checked the manifold bolts any suggestions
17th May 2017 02:51 PM
17th May 2017, 03:14 PM
Legendary
Not much info mate - but sounds like you are on the track, probably air leak somewhere, cracked manifold, manifold gasket or may be warped manifold. Without details of the motor its a hard one to call. Welcome to the forum by the way.
17th May 2017, 04:39 PM
SkippyGU
Does it the pitch change at all with engine rpm? And do you have a boost gauge installed?
17th May 2017, 05:02 PM
Any cracks or deterioration in the air pipe from the airbox, or to/from intercooler?
WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
17th May 2017, 07:20 PM
SkippyGU
Check all your intercooler rubber pipes as I found on my own patrol the heat and pressure had cause a tiny split in one of the hoses
All I can suggest is check all your boost lines and intake lines and pipes make sure everything is tight and not splitting
19th May 2017, 08:03 PM
Patrol Freak
Check the little alloy manifold that connects the egr stepper motor (I think it`s called that) that recirculates the exhaust gas back in to the motor, it may be warped at either end flanges. I had that problem after replacing the the stepper motor. I only noticed a whistle every time I took off at certain rpm and differing times in other gears when adding more power.
