Results 1 to 8 of 8
Thread: Sub Tank / Charge (battery) warning lights
    Jul 2016
    Hi all,
    started up my 01 GU ZD30 last night and while driving along the Sub Tank and Charge lights stayed on. Have read a few comments, one bloke changed his alternator and had success, but wanted to get as much info as I could. So if you know of anything could you please chuck in your opinions?
    - Not in limp mode
    - Has turbo timer
    - unsure of age of alternator
    - it does sound slightly different when idling. I know that sounds weird, but I have noticed a difference.
    cheers.
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    do you have a mulitmeter ? checking the voltage while its off then check it when the engine is running. should give you an idea if the alternator is working.
  4. The Following User Says Thank You to garett For This Useful Post:
    Orsm6 (16th May 2017)
    Jul 2016
    I haven't done that as yet mate. But I will be. Just wanted to start getting some info put together
    thanks for the reply
    Bayswater WA
    Had a similar thing that was dual battery system related after I bridged the solenoid to use the aux battery as a starter.
  7. The Following User Says Thank You to Mr Trol For This Useful Post:
  8. #5
    Jul 2016
    good to know. I don't have a dual battery set-up. but i'll inspect the wiring as there was a dual set-up before I bought car, maybe something rattled loose.
  9. #6
    Classic symptom of a shagged Alternator or, if your lucky, a fault in the Alt wiring.
    Check your Alt fuses, plugs etc and if all OK get the Alt tested
  10. The Following User Says Thank You to the evil twin For This Useful Post:
  11. #7
    Jul 2016
    measured 11.7 at battery under idle. I think she's fooked. Brand new drive belt so it isn't that, wiring looks OK. I haven't checked a fuse though.
  12. #8
    Jul 2016
    Found a broken wire before pulling out the alternator. In the past this has only thrown a check engine light, bugger. Time to open the wallet lol.
