Results 1 to 10 of 13
Thread: Hi or low mount turbo?
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    G'day all.
    Hoping for some advice on what the advantages/disadvantages are
    Of a high versus low mount turbos on a td 42
    Aug 2014
    Perth
    10 Post(s)
    I went for a high mount setup on my GQ partly because it was easier to work on, however if you want a top mount intercooler you might have issues running a high mount
  4. The Following User Says Thank You to gubigfish For This Useful Post:
    Deano2506 (14th May 2017)
    Apr 2017
    Hobart,tasmania
    Thanks for that.
    Makes sense too.
    I plan on running a intercooler after i get the turbo done,so that's very helpfull info
    Engine bay temps would be lower using a low mount setup. Further from the aux battery too if you have one. Easier intake plumbing maybe with a high mount though.
    Apr 2017
    Hobart,tasmania
    Another good point.
    I guess the turbo itself would run cooler with low mount too
    I think i read somewhere too about the flow dynamics. It was better with the low mount. But I'm not sure if it was about this or not. I run a low mount. If I was given the coice, low mount still. To me it just seems a better position and out of the way too... Doesn't look as good though...
    Deano2506 (15th May 2017)
  10. #7
    Apr 2017
    Hobart,tasmania
    Hmmm.flow dynamics...I'll look into that a bit more.
    I'm not worried how it looks just what goes better.
    Cheers for the info
  11. #8
    Aug 2014
    Perth
    10 Post(s)
    @nissannewby is probably the most qualified to talk about this
  12. The Following User Says Thank You to gubigfish For This Useful Post:
  13. #9
    Quote Originally Posted by gubigfish View Post
    Most definitely....
  14. #10
    North brissy
    Not sure about that
    A well designed high mount can be just as good as a low mount. Low mount I would be using a dts item. They are nice heavy cast and are very open and direct compared to a standard manifold.
    For high mount I would be using the latest item from radius fab recent testing by a well known shop has shown some nice gains over the standard nissan manifold.
    I dont see to much difference in where the heat and everything is. Piping is very similar unless you do run a top mount cooler then a high mount might cause some dramas. Depending on turbo sometimes wastegate actuator placement can be fiddly on a high mount setup.
  15. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (16th May 2017)
