Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: (nsw) TD42T 02 wagon
    Hardcore
    central coast nsw
    SOLD SOLD SOLD SOLD
    no longer available.
    DSCF8844.JPG.
    Owned Pat for just over 3 yrs now and know the previous owners.
    the list hmmm Iv'e been building Pat up for touring and now well Pat has to go sob sob.
    my Big loss.
    Tuff dog hsv damper.
    tuff dog adjustable panhards.
    superiour engineering hollow h/dty drag link and tierod bars.
    Koni shocks all round.
    Ome caster bushes.
    3 VDO gauges pyro temp and turbo psi.
    Diesel central reco injectors.new rail.
    DC3 injector pump. (diesel central)
    Garret GTX2863R turbo.
    Raduis fab 4" snorkle and air box.
    HPD intercooler kit.
    Dual battery.
    Domin8tor winch 1200lb plus h/duty 0 gauge wiring.
    Braided lines, all 7 of them, (to suit 3" lift).
    ARC radiator 2 row alloy, AU made not cheap import.
    front wheel & caster bearings & only gen seals used.
    Superior h/dty engine mt, near side.
    nearly all these parts have been fitted in the 18 mths and hasn't seen any real 4x4 off rd work,
    as I wrote touring vehicle, state forest & a couple logging trails only
    theres lots to go, will add more
    0411166465
    I'm avail just about all day and weekends.
    Asking $28000 ono
    DSCF6367.JPG.
    What else---
    When clutch was replaced front & rear main seals were replaced gen seals used.
    new clutch fork & carrier also.
    fly wheel was lightened 3kg (from memory) & balanced.
    Volt meter has been replaced with a similar unit but this one has 2 usb outputs also & 2 12v sockets now reside between the usb fittings all with independent switches and fuses.
    Reverse camera is set up for viewing at the flick of a switch , meaning you don't need to select reverse to see backwards, great towing.
    Water pumps also been replaced, again gen nissan part used still have the old one it feels ok but I don't take chances.
    Hid driving lights were removed but will go back on for sale.
    Rear mud flaps replaced with much larger ones to help stop stones hitting trailer etc 150mm longer and 460mm wide.old ones to go with car.
    Kenwood 2 din stereo, blue tooth, usb etc, still have oem unit.
    A few spare bits,set of glow plugs, thermostat n gaskets fan belts etc.
    Stainless air fittings front and rear bumper bars to be plumbed to a pump didn't finish install yet.
    be back with more soon
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  2. The Following User Says Thank You to Robo For This Useful Post:
    growler2058 (4th September 2017)
    Hardcore
    central coast nsw
    Ok taken some more pics and some More info.
    Gear box front input seal was also replaced while clutch was being replaced again gen nissan seal used.
    The winch control connection has also been mounted on the center console, No getting out in the muck to hook controller up.
    Winch solenoid up in the engine bay next to the starter battery away from the elements and 0 gauge marine cable used.
    Why fit a winch for touring well I did just incase I went somewhere I didn't know the terrain etc.
    and Its never been used other than initial retension and a few times to streached out to dry off
    Have to say all wiring has been marine grade "Tinned cable" (with heat shrink 99.9% of the time) didn't use heat shrink on usb and volt mtr, just crimps.
    Honestly I could keep going for hrs on all the little bits and bobs.
    last service 2000k ago.
    so your wondering why after the hard works been done well personal reasons only, no bloody way otherwise.
    And the boss said down to 30k
    318000 k so just run in.
    Rego 16/4/18
    swivel bearing seals etc being replacedDSCF7932.JPGDSCF7952.JPG.
    air boxDSCF7118.JPG.
    over ride buttons & winch socket DSCF0461.JPG.
    mud flapsDSCF0445.JPG.
    powerDSCF0453.JPG.
    over head consoleDSCF0450.JPG.
    mud flap off cut protecting the guideDSCF0438.JPG.
    stainless air fittings DSCF0466.JPG.
    Have you had it dyno'd with the new pump and turbo?
    Hardcore
    central coast nsw
    yeah mate something I missed good ? thanks.
    was going fine yesterday typing info & computer shut down loosing all my work just before heading off to work, hence the slack job on info.
    DSCF7125.JPG.
    148kw & 500nm atw .
    egt's pulling the 22 ft caravan going up long steep hills ( eg climbing up to dorrigo) haven't gone above 450 deg C so good tune in my eyes
    Hardcore
    central coast nsw
    Limited edition, came with the overhead console from dealer, think thats the extent of it.
    Attachment 71890.
    forget all the marks in pic around badges just dirty haven't tried to hide stuff and busy
    Pat didn't have an intercooler till I got it, so no expensive injector or computer old school KISS, less problems.
    Oh and was never fitted with an egr ex factory so no head ache there either.
    Attachment 71891
    Listing all the good stuff and work has me really regretting having to sell
    175 Post(s)
    Very tidy and clean Patrol there mate. A lot of attention to detail and very thorough and neat with the mods, e.g. Somebody will hopefully benefit from it. Shame its gotta go. Good luck with sale.
  9. The Following User Says Thank You to Hodge For This Useful Post:
    Robo (11th May 2017)
  10. #7
    Hardcore
    central coast nsw
    Thanks mate, regret sale, but the kids have to come first, all I can say.
    Let the phone calls begin------- now on carsales.
  11. #8
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Hey Robo, if you haven't already, chuck the ad on gumtree. I found most hits were of gumtree when I sold mine.
    Good luck
    ................on the road
    ________________________
    ______ 2017 D-Max _______
  12. #9
    Hardcore
    central coast nsw
    Good luck
    Cheers mate.
    the boss had already suggested that to, may give it a few days first.
  13. The Following User Says Thank You to Robo For This Useful Post:
    Maxhead (20th May 2017)
  14. #10
    Hardcore
    central coast nsw
    Revised price 28000 & open to offers. need gone asap
    And on day work next 6 weeks 1st to 15/8/17 available after 3.30pm weekdays,and all hours all weekend.
    Need gone now, who ever buys this is going to be very happy.
    very std go for 23+ and this has had near 20k spent on it in last couple of years so a bargain,
    I am not selling a lemon it's a great car, the boss said sell, it's her car and she wants something else.
    Happy wife happy life yeah!.
