Page 3 of 52 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 517
Thread: Blocking the EGR Valve
    G'day Kev,
    Going by the symptoms you're describing I'm guessing you also own a 3l GU Patrol? A bit more information will make it easier for us to help you.
    Tony
    Sep 2010
    Thanks for than G- Unit ive got a mate making me one up ill put in in this weekend
  4. #23
    Patrol Guru Timbo's Avatar
    East Melbourne
    No problems mate.
    I'm actually going to take the EGR probe thing out of the manifold on the weekend. I'm still getting an annoying whistling noise noise and it just HAS to be related to the EGR somehow.. I can't think of anything else, so this is the next step.
    Sep 2010
    The reference document posted is outstanding thanks for the detail
  6. #25
    Oct 2010
    Mount Isa
    I have blocked off my EGR, but i blocked it at the exhaust manifold end. Reason being, I thought it would reduce the heat being transfered along the EGR pipe. It may or may not make much differance.
  7. #26
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    Quote Originally Posted by Roady View Post
    It won’t make any difference. Most people just block it at the inlet manifold because it’s easier to do, but stopping the gas flow from anywhere does the trick and the alloy pipe from the valve to the inlet manifold no longer gets hot.
    One advantage to blocking it at the inlet manifold is that you no longer get oil building up in the EGR valve.
  8. #27
    581 Post(s)
    Stuck this thread, thanks Timbo.
  9. #28
    Oct 2010
    in this case timbo your just stating its a better way of utilising the power earlier im just aboutm to go this to my 2.8 td GQ and ill let you know how I go
  10. #29
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Hi Guys, If I happen to punch out a bunch of EGR blocking plates that slide in as described in the post above, would anyone be interested?,
    cheers The Ferret.
  11. The Following User Says Thank You to the ferret For This Useful Post:
    sherman tank (27th June 2011)
  12. #30
    Expert RustyNails's Avatar
    Morley - Perth WA
    Would be depending on what you make them out of.
    Stainless is supposedly the best, been looking around to find some off scraps but so far haven't found any./
    Paul
    Western Patrol Club member #27
    2.8TD GU --> The Red Rocket
