Page 55 of 55 FirstFirst ... 545535455
Results 541 to 549 of 549
Thread: Rosscos GQ Rejuvenation
  1. #541
    138 Post(s)
    OK, so a manual slide is replaced by an air operated slide. I know the free spool was a pain on both of my high mounts simply because they tended to seize up with inaction. I guess if the mechanics are inside the drum they are protected, and there probably is a lot more avail force to engage/disengage?
    Manufacturer of the Complete Camp Oven System
    Website:http://davesstuff.net/
    Vendor Page: http://www.nissanpatrol.com.au/forum...ar-That-Works/
    Tuturial Video's: http://www.nissanpatrol.com.au/forum...ted-on-Youtube
    324 Post(s)
    Somewhat similar to a starter motor bendix throwing into action except the exact opposite reaction I believe Philstar.
    I think when our air is applied it throws the cogg forward off the piston line for unhindered barrel release.
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    PeeBee (22nd June 2020), Rossco (23rd June 2020)
  5. #543
    148 Post(s)
    @Rossco, why is the mechanical free spool deleted? What's the mechanism on the air free spool that makes for the improvement?
    The old school warn way of free spooling is pretty crude really as you would remember. It's pretty dam hard top pull out as your spinning all the gears up to the motor. The freespool delete supports everything much stronger and also makes sure it can't pop out into freespool on its own. The air freespool is in the drum between the drum and spline which goes into the bottom gear so disconnects it right at the drum end. Can't really see it, mechanism is in center of drum but tested it on bench and seems to work, put air to it and will disengage. Assume it is a piston that moves a splined section in & returns with spring pressure or similar. .
  6. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (23rd June 2020), mudski (23rd June 2020)
  7. #544
    138 Post(s)
    Thanks Ross, yes it was a bloody pain especially when sitting for a while.
  8. #545
    148 Post(s)
    Yeah near on useless I reckon, lucky there's a million and one upgrades for them! At least spooling out with the motor aint too bad they're reasonably quick. .
  9. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (23rd June 2020), PeeBee (23rd June 2020)
  10. #546
    148 Post(s)
    Yay, winch back in and all seems to be working as it should. Just need to wire air solenoid hopefully get sum shed time next couple of nights. .
  11. The Following 6 Users Say Thank You to Rossco For This Useful Post:
    jay see (30th June 2020), MB (1st July 2020), mudnut (1st July 2020), MudRunnerTD (2nd July 2020), mudski (2nd July 2020), PeeBee (3rd July 2020)
  12. #547
    324 Post(s)
    Top Stuff Wossco, ready to roll
    If you haven’t already mate, be sure to secure the supplied Delta air line clip snugg to the passenger side casting plate.
    Mine came loose and allowed the line to twist up a rotation or two, think I zippy tied it back a few times along the line also to take some pressure off the pissy little clippy given.
    Rossco (1st July 2020)
  14. #548
    In Moderation
    351 Post(s)
    Nice one. Whats next on the list?
  15. #549
    148 Post(s)
    Probably use it lol, but maybe taller 5th gear if we ever get to stretch out legs and bring our germs to other states . .
  16. The Following 3 Users Say Thank You to Rossco For This Useful Post:
    Maxhead (2nd July 2020), MudRunnerTD (2nd July 2020), mudski (2nd July 2020)
