Page 62 of 64 FirstFirst ... 12526061626364 LastLast
Results 611 to 620 of 635
Thread: Rosscos GQ Rejuvenation
  1. #611
    192 Post(s)
    TBH I can't believe it kept pulling bloody amazing those High Mounts really thought threre was no chance looking at that back wheel buried in the goo. . .
  2. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    jay see (14th November 2021), Maxhead (13th November 2021), MB (13th November 2021), mudnut (13th November 2021)
    472 Post(s)
    Wossco’s Weekend Wecovery Thexy Twelve or Twenty Faw Thervices
    www.thexy1224thervices.com.au
    Rossco (13th November 2021)
  6. #613
    472 Post(s)
    Legend, THANKYOU
  7. The Following User Says Thank You to MB For This Useful Post:
    mudski (6th January 2022)
  8. #614
    109 Post(s)
    Quote Originally Posted by aronsteinn View Post
    Good luck with the swap mate!
    Oi mate just download the manuals. You don't need 25 posts.
  9. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    Avo (13th November 2021), mudski (6th January 2022)
  10. #615
    And that is when he stopped being and astrofuckinaut n started reading the farming rules...like a lepper in a hand out colony
  11. #616
    192 Post(s)
    Took a slight detour when on the road the other day and ended up at Roardrunner Offroad damitt
    . . Few snazzy bits for the old girl upgraded brake shaft for the HM some new rope & hook and finally got myself a big black dildo to strap on the front. . . Did notice she got unusually hot on one of the scorchers the other day and looks like front of air con condenser still pretty dirty from $1000 dollar track so as brake shaft was on the cards may a well get bar, grill and intercooler off to give a good clean from front side and hopefully all good . .
    Also found windscreen leak that has plagued me since the rebuild had replaced all scrivets thinking that was it but still no good. . Looks like windscreen seal so at least its tracked down bit so should be able to get it sorted
  12. The Following 7 Users Say Thank You to Rossco For This Useful Post:
    AB (29th January 2022), jay see (28th January 2022), MB (28th January 2022), MudRunnerTD (29th January 2022), mudski (29th January 2022), Touses (31st January 2022), Winnie (28th January 2022)
  13. #617
    194 Post(s)
    Ah where you be without a big black dildo in Christmas hills - I guess there isn't much else to do out there after you have strummed your way thru the same tooone 69 times!
  14. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    AB (29th January 2022), growler2058 (30th January 2022), MB (28th January 2022), Rossco (28th January 2022)
  15. #618
    Now that's a hook I'd like to trudge through swampy Tassie mud!
  16. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (28th January 2022), Rossco (29th January 2022)
  17. #619
    330 Post(s)
    Nice one mate. 12mm rope for the win. Awesome. What diameter us the dildo? Check out Markys. I highly recommend replacing that bottom bolt with a pin and clip so you can take it off while.commuting. winner.
    You will be impressed with the brake shaft too. It wasn't until.i fitted one that I realised how much of an upgrade it was, not just a circuit change.
    We need to get that 24v pumping mate!!!
  18. #620
    330 Post(s)
    You probably won't fit 40m of 12mm on your drum either. When I make the soft shackles I needed about 3m of 12mm per shackle FYI or.make a 10m extension strap (well 7m by the time you splice a loop in each end. Nice fluoro Orange for the win
