Page 19 of 64 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 635
Thread: Rosscos GQ Rejuvenation
  1. #181
    472 Post(s)
    Hell yeah Roofy mate, there were heaps. The night before we played the trick we had a pack of muts running across the next Eastern ridge howling at our fire. Quite daunting without guns TBH!
  2. The Following 3 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (23rd June 2017), Rossco (23rd June 2017), Sir Roofy (23rd June 2017)
    192 Post(s)
    Just dropped the cab off @ the panel shed, should be nice & silver by then end of next week if all goes to plan. Just need to prep the doors & bonnet and get them in there too. .
  5. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (23rd June 2017), Sir Roofy (23rd June 2017)
  6. #183
    192 Post(s)
    Well the body is off. . .
    She's a bit dirty under there. . Time for some cleaning. . .
  7. The Following 9 Users Say Thank You to Rossco For This Useful Post:
    AB (24th June 2017), Bacho86 (29th June 2017), Chappy (1st July 2017), jay see (2nd July 2017), matfew (24th June 2017), MB (26th June 2017), mudnut (24th June 2017), MudRunnerTD (28th June 2017), mudski (30th June 2017)
  8. #184
    Patrol Guru matfew's Avatar
    Nov 2012
    Good time to pull that pump off .
    I done my clutch when I had body off too and took me about 20mins to do haha
  9. The Following User Says Thank You to matfew For This Useful Post:
    Rossco (24th June 2017)
  10. #185
    192 Post(s)
    Yeah me & AB were looking at everything seeing how easy it world be to do. . . Crazy ! !
  11. #186
    192 Post(s)
    Well the cab has been painted, can't wait to see how it looks, came up alright aparently. I'll grab it Friday, have been busy striping & preping doors this week. Had to repair cracks in both the rear ones at the base of the window frames.
    One minor bugger but lucky i found it now,. Checked the new body lift blocks (1"), they're 50mm diameter which is smaller than the body mounts (80mm) so will have to get sum more bigger ones. . . Trying to get onto the supplier with no luck. They are black poly which i kinda like, if not might have to go ally which I'm sure should do the job too? ?
  12. #187
    Geez your guy didn't stuff around did he? Can't believe how quick you are powering through this
  13. The Following User Says Thank You to Winnie For This Useful Post:
    Rossco (28th June 2017)
  14. #188
    192 Post(s)
    Yeah he didn't want it taking up room in the shed. . . I thought sweet when he said that 😊
  15. The Following User Says Thank You to Rossco For This Useful Post:
    Winnie (28th June 2017)
  16. #189
    109 Post(s)
    I'd be wary of galvanic corrosion with alloy blocks Rossco. No expert but I'd either go poly or only use the alloy with separators between the body/chassis and the block.
    https://en.wikipedia.org/wiki/Galvan...alvanic_series
  17. The Following User Says Thank You to Plasnart For This Useful Post:
    PeeBee (28th June 2017)
  18. #190
    192 Post(s)
    Yeah would rather poly in black if i can find some. For this reason plus, they would look the least obvious and not sure if it would be true or not, but may transfer less vibration than ally. Hopefully i can get through to the supplier soon and he has some, if not can get some somewhere else soon . . .
    Sent from my SM-T800 using Tapatalk
