Page 44 of 64 FirstFirst ... 34424344454654 ... LastLast
Results 431 to 440 of 635
Thread: Rosscos GQ Rejuvenation
  1. #431
    192 Post(s)
    Nah he painted it, asked weather I wanted it silver or black. . . No brainer! Hopefully you can get the Nissan decal if not out comes the texta
  2. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    AB (23rd March 2018), MudRunnerTD (23rd March 2018)
    Maybe time for a new inlet manifold while it's out too Rossco, I don't reckon you've spent enough time or money on this car yet.
  5. #433
    192 Post(s)
    NO enoughs enough, time to enjoy it i reckon
    Not going to crank the bejesus out of it either just be happy with something that cruises nice can pull the Jayco without too much stress and has a little bit of power under the old foot if needed . . .
  6. #434
    192 Post(s)
    So got a little bit of shed time in today with some much appreciated help from Mudski, Nicko & AB cheers heaps dudes.
    Motor is ready to go back in the car now, manifolds and turbo is on. Had a bit of a drama with the exhaust manifold, didn't think that I had to remove the studs in it to put on the adaptor to suit the BorgWarner. Anyway tried to get them out and they wouldn't budge even with heat a welded nut so had to drill out & tap 3 of the 4 but they came up alright in the end. . .
  7. The Following 11 Users Say Thank You to Rossco For This Useful Post:
    AB (26th March 2018), Bacho86 (26th March 2018), GQtdauto (26th March 2018), Hodge (28th March 2018), jay see (25th March 2018), MB (26th March 2018), MudRunnerTD (26th March 2018), PeeBee (26th March 2018), Plasnart (27th March 2018), Wine_maker (26th March 2018), Winnie (26th March 2018)
  8. #435
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Looks noooice Rossco!
  9. The Following User Says Thank You to Bacho86 For This Useful Post:
    Rossco (27th March 2018)
  10. #436
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Looks great, Mate!
    Sure it will have a great thrust!
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
  11. The Following User Says Thank You to Wine_maker For This Useful Post:
  12. #437
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    bit of get up n go never bothered anyone...
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  13. The Following User Says Thank You to MB TD42 For This Useful Post:
  14. #438
    192 Post(s)
    So motor is now in and getting close. A few minor dramas along the away but all good. Cheers again to Markie (Mudski) & AB, dropped the motor in last night although wasn't completely smooth sailing. Seemed to take a while to line up then were having trouble getting bolts in. Had a look at the sandwich plate and noticed wasn't lining up with the bolt holes which didn't make sense at all, anyway pulled motor out and drilled the plate out a bit then put it back in easier this time.
    Came back to it this morning and noticed things still weren't lined up right then worked out what was going on. Felt a bit silly but lesson learnt and I guess it was getting late & tyred etc but reason holes weren't lining up was because the bracing mounts on both sides had been removed and put back in again were out of line. Loosed those then all good.
    Next oh s#!t moment was when I lowered it down into the mounts, with the turbo outlet facing down to work with the safari intercooler, it hit the chassis big time. Thought i was going to have to totally re think intercooler piping but rotated housing so outlet was facing the block a little more & dropped in with about 10mm clearance so hope this is all good.
    Decided to get it towed to the exhaust shop to get the dump pipe done so is off there tomorrow then will be close to firing up. Hope the thing works . . . Should do. . .
  15. The Following 9 Users Say Thank You to Rossco For This Useful Post:
    AB (28th March 2018), GQtdauto (28th March 2018), MB (27th March 2018), mudski (29th March 2018), PeeBee (28th March 2018), Plasnart (28th March 2018), TPC (29th March 2018), Wine_maker (28th March 2018), Winnie (28th March 2018)
  16. #439
    Jul 2014
    6 Post(s)
    Damn, I've loved this rebuild. So nice to see.
  17. The Following User Says Thank You to Throbbinhood For This Useful Post:
    Rossco (28th March 2018)
  18. #440
    192 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    Cheers mate, yeah enjoyed but looking forward to enjoying it soon.
    Got the dump pipe done today also had to get a new pipe made up from airbox to turbo cos the old Millweld one did didn't quite fit nicely with the new setup and was hitting badly on the back of the alternator. Anyways Lilydale mufflers & towbars did a really good job on it. Had to get it towed there & back, had it booked in twice before and had to cancel so think would have been pushing my luck postponing again lol. A few little things to finish & check over everything then might try starting it tomorrow sometime . . Bit scary tho !
  19. The Following User Says Thank You to Rossco For This Useful Post:
