4th May 2017, 07:33 PM
Patrol Goddess
High flow water pump
I am looking at fitting a high flow to my GU TD42 gas injected to help with overheating towing big loads.
Any suggestions. There's a mob on faceache but I cant find them.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
4th May 2017 07:33 PM
4th May 2017, 07:59 PM
The Following User Says Thank You to mudnut For This Useful Post:
4th May 2017, 08:34 PM
JPC sell one. I have one on my GU, Mudski and Mudrunner have one too I think. Price has gone up a bit since last I looked.
http://www.ebay.com.au/itm/JPC-Nissa...4AAOSwXYtY3Fto
The Following User Says Thank You to Hodge For This Useful Post:
4th May 2017, 09:46 PM
I'm honestly not sure that the 4.2s and or TD's as we have need a hi-flow Kat mate, clean em up as stock discussed:-)
The Following User Says Thank You to MB For This Useful Post:
4th May 2017, 09:55 PM
Adventurist
Not sure if you have considered going an all electric type pump like these from Davies Craig. http://daviescraig.com.au/electric-water-pumps
They do a few different models in either booster pumps or stand alone pumps for a variety of engine sizes and vehicles.
2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
The Following User Says Thank You to stevemc181 For This Useful Post:
4th May 2017, 10:04 PM
Patrol Goddess
MB
I've done most I can with it katrol is the primary tow truck ATM and I don't want to cook her.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
4th May 2017, 10:19 PM
katwoman
Turn the gas off and see what happens....
Also when you say overheating is this just what the factory gauge is saying or do you have an aftermarket one actually showing the temp?
The Following User Says Thank You to nissannewby For This Useful Post:
4th May 2017, 11:00 PM
Patrol Goddess
nissannewby
Factory gauge. Sits just under half, no matter what until the trailer and 2 tonne go on..Then straight up in the red
KATROL- The 2nd
GU TD42TGi
Silent member 1208
4th May 2017, 11:09 PM
Moderator
Do you have a Pyro EGT gauge?
Check out my Toy -->
Rogue Dung Beetle
4th May 2017, 11:11 PM
katwoman
What have you done with the cooling system up to this point?
