Results 1 to 10 of 16
Thread: Ecu/transmission computer
    Apr 2017
    Hi, my partner took his gq patrol out last weekend, got stuck in a bog hole for a couple of hours. He cooked the ecu, which I was able to find another to replace but the part number was different, got him out of trouble but it's like the car is still running in limp mode. Could the code duffence be the issue? We were told that it came out of a gq the same year/model as his. We were thinking that maybe it is the tranny computer? is it worth replacing it to see? If so the only one we can find has the same part number(assuming that's the first series of numbers on the label) but the numbers below are different. Would that work?
    Any other suggestions as to what may be causing this issue?
    He has done a full service on the car since getting it bogged, except for tranny fluid change.
    He has a 94 gq petrol efi patrol tb42 lwb
    Thanks for any help!
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    The ecu is on the passenger side behind the kick panel , could be a dodgy ecu or has he checked the tranny oil for colour and smell .
    If it's not a light sort of a red colour you may have cooked it , also get him to check the smell , ie does it smell burnt .
    I have a 94 diesel 4.2 with an auto and the best mod is a transmission oil temp gauge , vital to know what temp the oil is because if it gets too high you will cook the oil or worse the tranny .
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Where are you guys located @Ally91?
    Aug 2010
    17 Post(s)
    Is there actually such a thing as limp mode on the GQ's???
  6. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    GQtdauto (29th April 2017)
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Not on mine , there is an ATF warning light .
    Apr 2017
    We're in Melbourne, out near craigieburn
  9. #7
    Aug 2010
    17 Post(s)
    Yeh I've got the same light on my 92EFI GQ, just can't ever recall GQ's going into a "limp mode" like GU's
    What are the symptoms @Ally91????
    Also what is the ECU's part number you where supplied???
  10. #8
    Aug 2010
    17 Post(s)
    Quote Originally Posted by Ally91 View Post
    Bummer, if you where in Sydney I would of let you borrow my ECU and TCU for testing
  11. #9
    Apr 2017
    I'm assuming there is limp mode, the car wouldn't start once out of the bog hole. When he put the new ecu in it started but it's like he's only has 2 gears left... second and 4th I think he said. The new ecu had a different part number than the old one so we're not sure if that may be the issue
  12. #10
    Apr 2017
    The new ecu is 23710 35j00
    The old one is 23710 35j10
    We can get a new tranny Comp for $150, is the part number in the same spot as them? If it is, It has the same part no. But the numbers at the bottom of the sticker are different. I'm hoping that's a bath hi number or something?!
