26th April 2017, 07:53 PM
Turbo oil seal leaking
Hi all, I got a small oil leak under my turbo. 3 ltr common rail 2007, not big but want to fix, got all gaskets bought from Nissan ,was going to get of eBay and from turbo place but as it happens Nissan was cheaper by half lol. Never thought that, anyways it looks easy ? I'm going to undo from cat 3 bolts and engine mount one that holds cat then the oil drain at bottom 2 X bolts off then oil pipe that feeds turbo 1 X special one lol metal seals then take all pipe of from turbo then undo 3 X bolts on turbo to manifold then pull out all in one. Then undo oil feed on turbo change seal then put back with new seals ...... Have I missed anything . Is there an easyer way , will do this Monday so it should be good to drive ? Only a little oil not really dripping . Your thoughts
Thanks Dave
26th April 2017 07:53 PM
27th April 2017, 10:27 PM
All sorted. Taken 2.5 hrs. Not to hard just a pain to get all out with cat on lol. ,, no leaks now cool...
27th April 2017, 10:55 PM
You've done well I reckon .
28th April 2017, 10:24 AM
Had a friend help, but sitting on top of engine trying to wiggle the whole turbo with the cat on was a pain lol as it goes under the car and has a big bracket on lol The turbo was not tight on the 3 x bolts came of easy and I mean easy! but no leaks from it ? seal on turbo for oil was well backed on, Had to use a razer on it to get it of, everything else was easy happy
Dave
