Results 1 to 5 of 5
Thread: GU PATROL ZD30 Overheatimg
    Apr 2017
    G'day, having a few dramas with the uncles GU, car overheated a few weeks back found a water leak from the turbo cooling pipes, ordered genuine replacements & gaskets etc. fitted tipped up with coolant and bled system, car started overheating, figured still air in system tried bleeding again, no luck!! Told uncle to take to cooling system specialist, was diagnosed with blocked Radiator, bought new rad & thermostat to be sure, fitted bled system still overheating, thought maybe faulty new thermostat, removed & fitted dummy thermostat still the same, replaced rad caps, still the same, now I'm pretty much over it just thought someone else may have experienced the same 👍
    Do you have the correct radiator caps , the over flow bottle will have the spring release
    and the actual radiator cap is just a plain cap.
    Dec 2014
    Snowy Mtns
    My previous GU (2012) started overheating on hill climbs even when not loaded (boiling actually) Checked all the items you have then discovered it was the fan clutch. It was working but didn't respond enough when the load and heat came on. It twigged with me when I heard another GU fan.
    472 Post(s)
    Yep, there was another ZD30 on here overheating on tow just a few weeks ago, also turned out to be the viscous fan clutch not fully locking up when needed the most.
    Feb 2011
    Shed
    45 Post(s)
    Yup mine was a combo of thermostat and fan. Bastards loud as now
