23rd April 2017, 07:57 AM
Patrol GQ 4.2 - Engine Oil Recommendations
I read a few posts about GQ 4.2 Engine Oil Recommendations and wondered if anything has changed since then, I have a GQ 1989 Diesel 4.2 thats on 500,000km
Caltex Delo 400 Multigrade 15w40 seems to be a popular recommendation from posts about 7 years ago. (2010) but given that we are in 2017 has anything changed?
back in 2011, Tommo_C suggested
- Engine: Wesfil Z115 filters and Fuchs Titan GT plus 20W-50 Semi Synthetic oil, 10.4 litres
- Front diff: Fuchs Titan Gear HYP 80W-90 oil, 5.4 litres
- Transfer case: Fuchs Titan Gear HYP 80W-90 oil, 1.7 litres
- Gearbox: Fuchs Titan Gear 75-90, 3.9 litres
- Rear diff: Castrol Gear LSX 85W-140, 2.2 litres
back in 2009, Jeffs5 suggested
- Caltex Dello 400 Engine, - Engine 10L
- Front Diff 80-90 GL5, - Front Diff 5.4L
- Rear Diff LS140 GL5, - Rear Diff 3L (your's should be LSD , look for LSD sticker on rear of diff.)
- Transfer Case 80-90 GL4, - Transfer Case 2.2L,
- Gearbox 75-90 GL4. - Gearbox 3.9L
(Remembering diffs,g-box etc. won't take all those amounts as the gears hold oil.)
back in 2008, Patrol_Brad suggested
- Engine: Fuchs Ultra lube 1540
- Gearbox: Fuchs Titan Gear MP90
- Transfer case: Fuchs Titan Gear MP90
- Front diff: Fuchs Supergear 80W90
- Rear diff: Fuchs Supergear LS 85W140
Back in 2006 there's a comment from AussieMav91 on another forum:
One thing to Look for in the old TD42's, the Oil grade recommended is a CF, The Current latest is CJ-4 for Low emission engines. If you run a Higher Grade than CF you run the risk of oil burning because as you go higher grades the Detergents increase. More detergents means less carbon build up, and in the TD's carbon helps seal them rings from burning oil. So be weary of that!.
I look forward to your recommendations.
23rd April 2017 07:57 AM
23rd April 2017, 08:32 AM
Only know my mechanic puts semi synthetic oil in but can't remember the brand or numbers .
23rd April 2017, 09:00 AM
Having a high mileage motor you may need a different oil
@bigguwesty may be your go to guy on this one
BigRAWesty (23rd April 2017)
23rd April 2017, 09:05 AM
i still run dello no top up of oil or blue smoke. and 500 000 kms was a while ago. its been running dello since 93 ish.
23rd April 2017, 09:10 AM
Yep was running delo 15w40 up untill I sold it..
527*** on it and still went very well.
Changed every 5000km
Sent from my SM-G800Y using Tapatalk
threedogs (23rd April 2017)
23rd April 2017, 06:07 PM
I run shell rimula r4x 15w40 change oil every 10000km 93 model gq with 440000 on clock runs like a dream no oil topups between changes and motor is not sludgey like i have seen with some customers cars running other oils. Usally once they switch after two or 3 changes using rimula the motor gets cleaner. Have also had a few customers comment that their cars run a lot smoother after the change.
The Following User Says Thank You to MAP8P For This Useful Post:
GQtdauto (23rd April 2017)
