Results 1 to 9 of 9
Thread: Control Unit
    Apr 2017
    Control Unit
    Someone who has a clue what this is?
    Feb 2012
    Camden, NSW
    What model/engine?
    Where is it mounted?
    Looks like diesel engine pre-heat control. (Glow plugs or manifold heater.)
    Apr 2017
    Model 2004, Y61, inside and a looong cable into the engine compartment
    Expert Jimmyboyjr4's Avatar
    Penrith, NSW
  6. The Following User Says Thank You to Jimmyboyjr4 For This Useful Post:
    NissanGQ4.2 (24th April 2017)
    Apr 2017
    Thanks!! Jimmy
    Apr 2017
    Any idea where I will put it again? Have been hanging since I bought the car.
  9. #7
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by MrPekko View Post
    That's a good sign that somebody's been fiddling with it. It should be secured 'cos it looks like the ECU.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  10. #8
    Penrith, NSW
    Not entirely sure where is goes but if you judge via the cable lengths you should a general idea of where it goes. Try looking for any captive nuts or slots it could be bolted too, should help you figure out where it lives.
  11. #9
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Not sure on the GU's but on the GQ's the ECU is located behind the passengers side firewall.
    The thread below will show you how its mounted
    http://www.nissanpatrol.com.au/forum...ontrol+unit%3B.
    When you get a chance can you pop into the introduction section of the forum ( link can be found in my signature ) and post up an intro about urself and ur rig.
    Toddie
  12. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    threedogs (25th April 2017)
