16th May 2017, 08:02 AM
Sub Tank / Charge (battery) warning lights
Hi all,
started up my 01 GU ZD30 last night and while driving along the Sub Tank and Charge lights stayed on. Have read a few comments, one bloke changed his alternator and had success, but wanted to get as much info as I could. So if you know of anything could you please chuck in your opinions?
- Not in limp mode
- Has turbo timer
- unsure of age of alternator
- it does sound slightly different when idling. I know that sounds weird, but I have noticed a difference.
cheers.
16th May 2017 08:02 AM
16th May 2017, 08:11 AM
do you have a mulitmeter ? checking the voltage while its off then check it when the engine is running. should give you an idea if the alternator is working.
The Following User Says Thank You to garett For This Useful Post:
16th May 2017, 08:19 AM
I haven't done that as yet mate. But I will be. Just wanted to start getting some info put together
thanks for the reply
16th May 2017, 08:44 AM
Had a similar thing that was dual battery system related after I bridged the solenoid to use the aux battery as a starter.
The Following User Says Thank You to Mr Trol For This Useful Post:
16th May 2017, 08:53 AM
good to know. I don't have a dual battery set-up. but i'll inspect the wiring as there was a dual set-up before I bought car, maybe something rattled loose.
16th May 2017, 12:04 PM
I am he, fear me
Classic symptom of a shagged Alternator or, if your lucky, a fault in the Alt wiring.
Check your Alt fuses, plugs etc and if all OK get the Alt tested
16th May 2017, 01:53 PM
measured 11.7 at battery under idle. I think she's fooked. Brand new drive belt so it isn't that, wiring looks OK. I haven't checked a fuse though.
17th May 2017, 08:28 AM
Found a broken wire before pulling out the alternator. In the past this has only thrown a check engine light, bugger. Time to open the wallet lol.
