Results 1 to 5 of 5
Thread: Whats involved fitting Gu td42 turbo kit on to gq td42?
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    2 Post(s)
    I'm looking into buying a full turbo kit off a gu for $1200.
    Wondering if anyone else has done this and what's involved?
    It's a silvertop with 190000 ks
    Runs sweet as
    Already has 2 3/4 exhaust system
    581 Post(s)
    Pretty much exactly the same mate.
    You'll have to feed oil to it from the bung on LHS engine mount on the silver top and tap an oil drain into the sump.
    You'll also have to mod up some coolant feed and drain lines but easily done.
    What turbo kit is it? Comes with Inter cooler and piping too?
    Bit of a read but link below for a GU HT18 turbo onto a silver top td42 NA will show you.
    http://www.nissanpatrol.com.au/forum...-to-a-N-A-TD42
  4. The Following User Says Thank You to AB For This Useful Post:
    Deano2506 (19th April 2017)
  5. #3
    Apr 2017
    Hobart,tasmania
    2 Post(s)
    Thanks for the info.
    It's a factory early non intercooled gu set up.
    Are they all watercooled?
  6. #4
    581 Post(s)
    Some are and some aren't.
    $1200 is up on the high side of the price. How many kms has it got?
    Does it come with everything, cross over pipe, etc.
    The link I gave above is your turbo...
  7. #5
    581 Post(s)
    Oh you also need the manifold. Does that price come with the manifold?
