Results 1 to 2 of 2
Thread: GU Up and running
    May 2016
    8 Post(s)
    GU Up and running
    Hi all the Ute is up and running !
    Fuel tank removed and cleaned .
    new Ecu , lots of new oil and filters ,
    All is well just a few more things to sort out .
    Have the sub tank light on on the Dash ?
    and have to remove the sub tank clean out and fit a drain plug .
    I have made some tank Bosses to solder into the tanks so I can now drain them .
    Its a hard way to work out how the thing works bur well worth it .
  2. The Following 2 Users Say Thank You to Tip12345 For This Useful Post:
    GQtdauto (18th April 2017), threedogs (18th April 2017)
    Apr 2017
    yep that sub tank light is a bit of a mystery. mine comes on ocassionly but at the same time as the filter light and generator light. they must be sourced together somehow but it doesnt seem to affect the operation of the subtank. some old loose connection i think.
