Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Using flame to seat tyre beads.
    I have seen a few people use ether and the like to seat tyres. Tyre fitters over-inflate tyres up to 80-90 lbs to seat the bead. They then air it down to the recommended pressure.
    Using flame to seat the bead could potentially exceed the tyres designed pressure and cause internal problems with the steel belts and sidewalls, couldn't it?
    Can the by-products of the burnt fuel cause perishing to the inner surface of the tyre?
    https://www.youtube.com/watch?v=QbHpjttWrEA
    Is it a safe practice or just a dangerous, lazy man's method?
  2. The Following User Says Thank You to mudnut For This Useful Post:
    GQtdauto (18th April 2017)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    It's the redneck method I think , have not and will not try it myself and as you say what will the residue do to the rubber .
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I've never had an issue seating tyres with a 12volt compressor, a couple of taps with a rubber mallet and they usually seat the bead no problems for me. I guess if you have damaged beads or rims then it could do the trick in an emergency, but I'd try the ratchet strap and a thick layer of tyre lube first along with the rubber mallet or bouncing the tyre method.
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  6. The Following User Says Thank You to stevemc181 For This Useful Post:
  7. #4
    .......... TPC's Avatar
    63 Post(s)
    Have always found a bit of soapy water and 12v compressor has worked fine.
    I think the aerosol-flame method is just done for show.
  8. The Following 2 Users Say Thank You to TPC For This Useful Post:
    GQtdauto (18th April 2017), mudnut (17th April 2017)
  9. #5
    I have been next to a mower tyre that failed just after it seated. It blew out just above the bead and scared the hell outta me. Imagine if that happened with a jet of flame coming out.
  10. The Following User Says Thank You to mudnut For This Useful Post:
  11. #6
    Expert johno90's Avatar
    Moranbah QLD
    Sometimes you dont have a choice but to do it, but always as a last resort. Normally when you get tyres that have been stored for a long time all stacked up and it squishes the sidewall in. No amount of elephant, ratchet straps and hammering will seat them. But obviously be smart about it you dont need alot
  12. The Following User Says Thank You to johno90 For This Useful Post:
    mudnut (18th April 2017)
  13. #7
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I've done it a few times. It works well
    Sent from my E6653 using Tapatalk
    Lucus30's 1999 GU ST TB45E
  14. The Following User Says Thank You to lucus30 For This Useful Post:
  15. #8
    Just a redneck thing imo, with todays compressors
    you should be able to re-seat any bead that pops
    off while 4x4ing, yeah just theatre. Too many
    things might go wrong, 16" BMX tube is helpfull
    when re-seating a tyre
  16. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    GQtdauto (18th April 2017), mudnut (18th April 2017)
  17. #9
    16" BMX tube is helpful when re-seating a tyre
    Please explain.
  18. #10
    I watched when they have changed mine over the years having workshop access, the 16" BMX tube would fit over the rim
    onto of the tyre taking up any slack, then just give a burst of air the BMX tube will pop off when the bead seats.
    A few shops Ive been to have used this method,,,,,,
    Note the BMX tube will have a little air in it, other wise it would not work
    Pressurize gas and a flame is just asking for injury IMHO
    avoid at all cost ,,have you seen even a can of fly spray
    explode.??
  19. The Following User Says Thank You to threedogs For This Useful Post:
