16th April 2017, 06:00 PM
GQ Brake Lights
Hey Everyone. I bought a new brake light assembly for the GQ in January and it has worked fine, however recently whenever I have the headlights on, the left rear brake light stays on. When I tap the brakes, the left brake light does nothing, it just stays lit. When the lights aren't on, both brake lights are fine. Obviously this needs to be fixed, I don't need attention from the cops. Help will be appreciated. It's a 1989 TD42. Thanks, Corey.
1989 GQ TD42 N/A.
16th April 2017 06:00 PM
16th April 2017, 06:06 PM
Is the light a combined park/brake globe. Then check earth for left light. Park light is earthing through brake light.
16th April 2017, 06:12 PM
Hey Mate. You wouldn't happen to know where the earth ends up would you? It's a combined globe, yes.
16th April 2017, 06:28 PM
Check the bulb itself for corrosion .
16th April 2017, 06:31 PM
Thanks mate, there's none it's a brand new assembly and bulbs.
16th April 2017, 06:34 PM
is the globe in the right way ? eg i've seen the wires backward so you get brake all the time with parkers. cheap Chinese stuff
16th April 2017, 06:47 PM
garett
You may be onto something because it's a new assembly the fault should be in the assembly.
16th April 2017, 06:54 PM
#8
Thanks for that, I'll check that tomorrow when I have some light. Would that be the plug?
1989 GQ TD42 N/A.
16th April 2017, 07:21 PM
#9
could be wired wrong it could be just a backwards globe. if its wireing you can pop out the connecting bit with a pick or pointy object and swap for the correct one. test light is your friend
17th April 2017, 08:33 AM
#10
Corsta0211
Most likely it's the globe. GQ brake light globe is a dual filament one. One for parking & one for brakes.
When a one end of a filament ends up fusing with the other due to a factory fault of the globe, above bizarre behaviour can be the result.
Swap the globe and I would say that will fix the problem.
One thing you can do to confirm or rule out it's the globe is to swap the brake light globes from the faulty side to the other side and see if the problem moves to the other side. If it does, then it's definitely the globe.
The Following User Says Thank You to dom14 For This Useful Post:
GQtdauto (17th April 2017)
