Results 1 to 10 of 10
Thread: Front control arm bushes
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    I'm looking at replacing front control arm bushes and I see that OME are the best. But I've noticed that superior engineering have a slotted genuine Nissan bush for $90 each. Are they worth getting over the standard Nissan bushes for $90 a set of four from Patrolapart?
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    What do you mean by slotted?
    Do you have a links 2 both products???
    330 Post(s)
    Quote Originally Posted by Chubba View Post
    No. The slot is supposed to flex better but seriously shorten their life. Go the OEM for sure .
  5. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Chubba (14th April 2017), macca (14th April 2017), my third 256 (14th April 2017)
    North brissy
    Genuine nissan bush can be had for $28ea AUD plus shipping out of dubai.
    330 Post(s)
    Is that for 4?
    North brissy
    Or $15.43ea AUD for the same part number patrolapart are listing for the 4 at $90.
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (14th April 2017)
  10. #7
    North brissy
    Is that for 4?
    Whats after the 28? And look up lol
    The $28 one is the most recent revision of the part but the others ones are available still and are nearly half the price.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
  12. #8
    Oct 2013
    Adelaide
    5 Post(s)
    The slots as Mudrunner said increase flexs. It's not a great photo but if you zoom in you can just see them. https://www.superiorengineering.com....filter=141,355
    As for the standard here from Patrolapart for far less coin.
    http://patrolapart.com.au/product/ni...h-set-diff-end
    Thanks Mudrunner
    "GO YOU CROWS"
  13. The Following User Says Thank You to Chubba For This Useful Post:
    NissanGQ4.2 (14th April 2017)
  14. #9
    330 Post(s)
    Thanks Mudrunner
    Wow $79 each!! Superior Tax right there mate. I have a heap of Superior hear and rate it but damn they can price some gear.
    That is an OEM bush with a couple of holes drilled through the rubber. No shit. I have run these bushes before Superior put their Royalty on them and they lasted less than 1500kms of hard flex driving. The holes just let the Centre tear straight out.
    Here is a quote from my build thread.
    Now i hear you ask "Why do you need the hoist MR??" Well the Front Radius Arm Flexi-Bushes i fitted in the build 1500kms ago are ROOTED too!!! NOt happy Jan! The Rubber ones that i took out that Mr Nissan fitted some 350,000kms ago where like new by comparison to these.
    Well i only have grass in the back yard at the moment and for safety's sake i wanted to do it on the hoist and had use of aq press while i was there===>> Bonus!
    These pics will blow you away!! They Blew me away!
    Bush #1
    Bush #2
    Bush #3
    Bush #4
    NOT MUCH CHOP HEY!
    Trashed and Crappy.
    OK Get this S#$t OFF my Truck!! NOW!
    1500kms old!
    Hope that helps.
  15. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Chubba (14th April 2017), threedogs (14th April 2017)
  16. #10
    Oct 2013
    Adelaide
    5 Post(s)
    Thanks mate. You've made this call and easy one.
    "GO YOU CROWS"
