Results 31 to 33 of 33
Thread: Troubleshooting Diff Lock Issues
  1. #31
    Feb 2011
    Shed
    45 Post(s)
    Actually, this could be a good thread for troubleshooting diff lock issues but the thread title is not the best
    @AB
    @MudRunnerTD
    @growler2058
    Done!..........
  2. The Following User Says Thank You to growler2058 For This Useful Post:
    Maxhead (20th April 2017)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Legend
    ................on the road
    ________________________
    ______ 2017 D-Max _______
  5. #33
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Hey Rod, Thank you so much for your help!
    Took it into Nissan and they farked me around as usual.
    They said I had a split hose which sucked mud into the diff actuator and vac solanoid . No idea how it would suck anything into the diff actuator as the vac is from solanoid???
    They did say the diff lock was working........any way the car is sold now
    Once again THANK YOU for your help!
    Did they replace the solenoid?
    They might have just disconnected both vacuum lines at the solenoid and blowed compressed air through it. This might of dislodged the dirt?
    I got my diff centre back the other day and both sides of the teeth are damaged. So I’m guessing this means that my rear locker was damaged going forwards and backwards. Making me suspect my problem might of been caused by low vacuum not allowing the actuator to fully engage the locker.
    I remember seeing a vacuum pressure chart when I was looking up the wiring diagram the other week. I’ll see if I can find it and add it this this thread.
    Glad you got it sorted.
  6. The Following User Says Thank You to Yendor For This Useful Post:
    MudRunnerTD (21st April 2017)
