Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: GU just died???
    Legendary happygu's Avatar
    Wayne,
    No Smoke indicates it is most likely not Piston related, but more fuel system / crank sensor / turbo not boosting
    Check that the Turbo is operating, as the vacuum hoses can split or fall off causing no boost, or the turbo vanes may be stuck open.
    https://www.youtube.com/watch?v=Fmg_LEVoTHM
  2. The Following User Says Thank You to happygu For This Useful Post:
    Wayne01 (11th April 2017)
    461 Post(s)
    Yeah if you have holes a piston your gonna know about it. And so will the cars behind you.
  6. #13
    Apr 2017
    Berwick VIC.
    Thx Hodge. I will search on how to check the valve. May also explain why the primer bulb won't get hard.
  7. #14
    Apr 2017
    Berwick VIC.
    I didn't see any smoke. I hope to do a comp test on her today and with luck rule out the piston theory.
  8. #15
    Apr 2017
    Berwick VIC.
    Just an update:
    I pulled out the glow plugs but my Comp tester is an old spark plug type and would not do the job, however I threaded a bit of 10mm aluminium tube and screwed that into the plug holes.
    There was little to no compression from 1 & 2 (I could block it with my finger) and heaps from 3 & 4 (blowing my finger off). Even without the gauge it is really quite noticeable. Looking now at a swap over.
    Thx for the help ppl.
  9. #16
    @Sir Roofy There is a great place for motors on your side of town
    name escapes me but sir roofy will know
  10. The Following User Says Thank You to threedogs For This Useful Post:
    Wayne01 (21st April 2017)
  11. #17
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Logues Auto Wreckers Morwell 03-51346744
  12. The Following 2 Users Say Thank You to Sir Roofy For This Useful Post:
    threedogs (14th April 2017), Wayne01 (21st April 2017)
  13. #18
    Nov 2010
    Getting a life...
    38 Post(s)
    Quote Originally Posted by Sir Roofy View Post
    Commonly known as 'Rouges' wreckers.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  14. The Following 3 Users Say Thank You to katwoman For This Useful Post:
    Sir Roofy (15th April 2017), Wayne01 (21st April 2017), Winnie (15th April 2017)
  15. #19
    TRAFALGAR VIC
    35 Post(s)
    Yes true in every thing you want but who doesn't these days
  16. The Following User Says Thank You to Sir Roofy For This Useful Post:
    katwoman (15th April 2017)
