Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 115
Thread: PWM or MPPT.
  1. #61
    67 Post(s)
    Question how close to the battery do these things have to be, 600mm-900mm
    enough??? no eye dear lol
    As close as possible & practical. However NOT inside a small enclosed space WITH the battery where gas could build up. Although most unlikely you should never risk putting ANY electrical equipment which has a potential to create a spark in an evironment which could possibly become explosive. With AGM/Gel batteries the risk is minimal, but they can gas in some situations. The risk is far higher with wet batteries.
    Wet batteries should never be inside the vehicle.
    2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, ARB fridge, ARB freezer, Built in kitchen, 240v, 3 Genie exhaust + dynotune, 2 lift, Lovells GVM upgrade, ROH Blaktrak steel wheels, Bridgestone D697s, Redarc gauges/pillarpod, Hema HX-1, CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, Tyredog TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 195 litre water storage , OzTent RV3, plus 2010 Tvan Tanami. (incl another 110 litre water storage) with matching wheels/tyres (& 3rd spare)
    A Nomadic Life
    The Big Trip Blog
    27 Post(s)
    Thanks Cuppa.
    That makes sense...
  4. #63
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Quote Originally Posted by Throbbinhood View Post
    There's a handy excel spreadsheet on the myswag forum that helps calculate expected amp usage for various things (fridges/lights etc), then you plugin your batteries/panel sizing etc and will give you estimate usage rates, how many days you'll get out of x etc. Its good kit.
    You wouldn't have the link by chance?
  5. #64
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    where would you mount it, Im thinking of mounting my mppt somewhere
    inside the bullbar on the AUX battery side,
    I mounted mine above the glove box, out of sight and can be accessed easily if needed. My aux batt is under bonnet so as close as I could while remaining out of elements and engine heat. If I had a rear battery which may happen one day, I would relocate to the cargo barrier.
  6. The Following 3 Users Say Thank You to sooty_10 For This Useful Post:
    Hodge (15th April 2017), jay see (15th April 2017), threedogs (15th April 2017)
  7. #65
    Patrol Guru
    Jul 2014
    6 Post(s)
    Quote Originally Posted by Covo71 View Post
    Here is the link. http://symon.id.au/symon/myswag/Symon%20Solar.xlsx
    Please note this is an excel spread sheet.
    Thanks to Symon from the Myswag forum for the spreadsheet, hopefully doesn't mind me sharing it here.
  8. The Following 3 Users Say Thank You to Throbbinhood For This Useful Post:
    Clunk (24th April 2017), Covo71 (22nd April 2017), threedogs (18th April 2017)
  9. #66
    75 Post(s)
    I already have some decent sized cable coming from
    the Aux battery to the bullbar a run of about 500mm,
    terminating at a 50amp anderson plug. I should be
    able to wire my weather proof MPPT reg up inside the grill
    I think. Also need to change the 50 amp anderson to a fully fitted job
    GQtdauto (18th April 2017)
  11. #67
    Hardcore GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    33 Post(s)
    Still playing with the setup on the GQ , might pee off the 20 watt and just use the 100 watt for now .
    Just have to solve the age old question of where to put the reg without running the wires too far although it looks like yours is sorted .
    Thinking that the trip to the corner country next month will let me know the problems with the system if any and then I can fix it before next years 6 month trip hopefully to the cape .
    Fancy looking Anderson plug you have there .
  12. #68
    75 Post(s)
    Like you I have a small 10 watt panel, Im thinking that would be OK to hook up to
    start battery to keep it "busy",
    Must also figure out how to have a solar outlet at the back I have that cig,merit and guage
    for the small cut out, this would come in handy depending on the camp site,,
    position of the sun etc, somehow I need to get my Patrol fixed first.lol
  13. #69
    Dec 2016
    Northeast Victoria
    33 Post(s)
    Yeah everyone's rig is setup slightly different TD , and we all have our own ideas sometimes right sometimes wrong .
    Still haven't finished my setup I'm busy doing other stuff and charging up a mates dead ride on mower battery which has gone from 5 volt and .1 amp to 11.65 volt and .78 amp after one full day on the GQ 100 watt solar and holding .
    So will keep it up for a couple more days and see if it restores the battery , I notice the equalisation charge is pulsing 16.5 volt into it to try and shock it into life .
  14. The Following User Says Thank You to GQtdauto For This Useful Post:
    threedogs (19th April 2017)
  15. #70
    Patrol God bigguwesty's Avatar
    36 Post(s)
    Well just doing a quick hunt and found the VE 75/15 with Bluetooth dongle for $195.
    Dongle is $65 alone so about a $20 saving..
    Look at this on eBay http://www.ebay.com.au/itm/391646943763
    Sent from my SM-G800Y using Tapatalk
  16. The Following User Says Thank You to bigguwesty For This Useful Post:
    GQtdauto (24th April 2017)
