Page 12 of 12 FirstFirst ... 2101112
Results 111 to 115 of 115
Thread: PWM or MPPT.
  1. #111
    174 Post(s)
    Hi jay see
    Phone charging takes 3/5ths of bugger all. Lights vary considerably depending on type. Of course lots of phones add up to more.
    50l fridge will most likely draw 3.5 to 4 amps, & if being run as a fridge & not opened too often, will run around a 50% duty cycle. 42Ah to 48Ah each 24 hours. Unless you are running a bunch of Halogen lights 50 to 60 Ah's should cover your needs over the 4 days.
    A 200w panel in perfect solar conditions at this time of the year will feed around 50 to 60Ah a dainto your battery, possibly a bit more, so you should be ok, even if the weather is not perfect you should have sufficient capacity to get you through the 4 days until you can recharge the battery at home.
    For longer periods I would advise greater solar capacity & looking to the future it would be a wise move to buy a regulator with sufficient capacity to cover that now, rather than having to buy another reg in the future. If you buy a good quality reg they are generally capable of operating at full capacity & often a little over (cheap ones are the opposite). I would think that 300w of panels would cover you indefinitely year round for what you have said you want to run. 300w would manage with a quality 20 amp reg.
    I suggest that a 200w panel is a pretty cumbersome & heavy thing to lug in & out of the car. My preference would be to use 100w panels.
    My apologies for a delay in replying too. Haven't had any phone connectivity for a few days.
    49 Post(s)
    Hi jay see
    A 200w panel in perfect solar conditions at this time of the year will feed around 50 to 60Ah a dainto your battery, possibly a bit more, so you should bee ok, even if the weather is not perfect you should have sufficient capacity to get you through the 4 days until you can recharge the battery at home.
    Thanks Cuppa no need for an apology.
    The folding panels all seem to be the same lengths, the height is what changes and not by that much about 100mm.
    I'm getting a 200w folding panel and will upgrade it as suggested. As for adding more we'll see if we needed.
    There won't be any harm in adding the 20amp reg now?
  4. #113
    174 Post(s)
    Look for a good brand of regulator.
    Morningstar & Victron make good affordable ones .
    Better to buy a good PWM only one than a cheap MPPT.
    https://www.solaronline.com.au/victr...regulator.html
    http://www.ebay.com.au/itm/NEW-Morni...8AAOSwKQ9Z60MG
    Bypass/remove the reg supplied on the rear of the panel.
    Change the supplied cable for thicker cable. You can determine what thickness (thickness of copper core in mm2) according to length from this table. http://hobohome.com/news/?p=581
    Do not scrimp on cable size! It makes a big difference.
  5. #114
    49 Post(s)
    Thanks again mate.
    Should be going camping next weekend, but won't have enough time to change things around. Will do it before the Easter trip tho.
    Have taken all on board.
    Does doesn't there need to be a fuse between the battery and the panel right? Just a regular.
  6. #115
    174 Post(s)
    Put a fuse between the battery & the regulator, as close to the battery as possible. It's purpose is to protect the wiring from getting too hot & causing a fire in the event of a short circuit. It's rating needs to be higher than the regulator's output so a 25 amp or 30 amp one will suffice in your case. Best not to use a standard auto blade type fuse, (they can become a fire hazard themselves over time when used in this type of situation). A manual resettable circuit breaker is a good idea as it allows for disconnecting the panels too. Auto reset fuses/circuit breakers are a lousy idea as I found out recently. They can make fault finding far more difficult than it needs to be.
    https://www.ebay.com.au/itm/DC-12V-2...EAAOSwoddaa~1s
    https://www.ebay.com.au/itm/30-Amp-M...EAAOSwL5BZyiLr
    No fuse required between panels & regulator.
  7. The Following User Says Thank You to Cuppa For This Useful Post:
    jay see (25th February 2018)
