14th April 2017, 10:32 AM
#51
Hardcore
sooty_10
This is the solar controller I run. I didn't get it from this seller so shop around.
I also have a Bluetooth dongle for it so I can check it out on my phone.
Gives me 30day history with total times in each charge mode. Voltages customisable through the app for the different modes too.
I have a 160W folding panel on the roof and car doesn't move often these days. Fridge is on permanent with it.
Wow I was going to get a victron any way but I guess now I'll be getting the Bluetooth dongle too. Looks like a great bit of kit
Sent from my E6653 using Tapatalk
Lucus30's 1999 GU ST TB45E
14th April 2017 10:32 AM
14th April 2017, 10:42 AM
#52
Travelling Podologist
lucus30
Yep, I don't think you'll regret it.
The Following User Says Thank You to Cuppa For This Useful Post:
GQtdauto (14th April 2017)
14th April 2017, 11:43 AM
#53
Patrol Guru
Cuppa
They are a quality unit. My original pwm on the back of the solar panel (cheap Chinese crap) was always dying and never could use the solar panels properly eg. In the sun. This controller runs flawlessy.
14th April 2017, 12:40 PM
#54
14th April 2017, 01:08 PM
#55
I think I will end up with one of these .
14th April 2017, 04:50 PM
#56
GQtdauto
where would you mount it, Im thinking of mounting my mppt somewhere
inside the bullbar on the AUX battery side,
Question how close to the battery do these things have to be, 600mm-900mm
enough??? no eye dear lol
14th April 2017, 05:28 PM
#57
Might fix mine to near the spare batt in back but do a fly lead .
14th April 2017, 09:41 PM
#58
14th April 2017, 10:08 PM
#59
Thought that might happen , the PWM reg on my 200 watt panel is going bonza, the one on the 100 watt is not delivering the power it should be and yes it's a cheapie and about a year old .
Given that I've got 2 spare batteries in the GQ both gel cell I've been watching the charging over the last two days and I'm not getting past 13.8 , these are new batteries and I don't want to take a chance now I know I could have a problem .
Because most regulators are not water proof and I'm limited for where I can mount any regulator I like the idea of the app , so I can mount the reg on cargo barrier behind fridge and still know what it's doing .
The 200 watt panel is mounted on my camper trailer in the shed and I'm not sure it's getting any direct sunlight at all but every time I check it the volts are 13.3 so no need for me to touch that PWM reg as it's obviously a good one .
Not all PWM regs are crap and the one on the 200 watt panel is proof of that and it came with the panel so I have no idea of quality price etc I just know it's working very well .
Of the cheap regs I have brought over the years and ones that came with portable panels all have been replaced except one , but I don't look after my stuff and leaving them in the rain and heavy mist/fog has cost me a couple for sure .
I do now tend to look after things a bit better .
The Following User Says Thank You to GQtdauto For This Useful Post:
jay see (14th April 2017)
14th April 2017, 10:45 PM
#60
jay see
Now you guys have really confused me.
Cuppa
No need for confusion! Previously I recommended a cheaper Victron on the basis that it was good value & from a manufacturer with a reputation for quality. This reg that Sooty posted is from the same manufacturer but a step up in regard to being MPPT (which would be genuine MPPT, not just letters on the outside of the case) & more so because of it's ability for remote monitoring on a phone (for additional cost). Also the previous one I recommended was a bit small for the 200w of panel(s) you mentioned. This one is the next size up (15 amp instead of 10 amp) & would cope with up to 250w pane(s). If you want to keep costs down restricting yourself to 170w panel(s) & are happy to have no monitoring the previous Victron reg would be a reasonable choice.
The Following 2 Users Say Thank You to Cuppa For This Useful Post:
jay see (14th April 2017), sooty_10 (15th April 2017)
