Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Relay Chattering/Cycling Noise ??????????
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    The are a few relays that I’m aware of in the LHR quarter panel, there’s two that are part of the rear A/C unit and one for the rear power socket. The power socket relay is mounted at the front of the quarter panel near the seat belt retractor for the passenger LHS second row seat.
    The noise isn’t coming from the door lock actuator in the small barn door is it?
    Another possibility is a blocked drain tube for the rear A/C??
    If the noise is coming from a relay it more then likely won’t be a faulty relay. It will most likely be something electrical that is trying to keep/switch the relay on. Anything electrical been added to the vehicle lately? thermo fans? anything plug into the front cigarette light or power socket?
    Thanks Yendor,
    It's not the door lock, I think your last sentence may be the answer.
    I've recently plugged a couple of new USB chargers into the lighter and power sockets. I notice they have led lights in them and once the car is turned off it continues to light up as it's draining from the battery on the dashcam.
    Assuming that's just enough power to cycle the relay till the camera battery goes flat. Going out to unplug it now which I have been doing most times, but I know it's plugged in now. I'll keep you updated, this explains why it's intermittent.
    Again thanks for your advice, always like reading your replies to others issues/questions. Knowledgeable and always helpful.
    Cheers mate
    Jack
  2. The Following User Says Thank You to jack For This Useful Post:
    Yendor (8th April 2017)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by Apollofish View Post
    Thanks Yendor,
    Cheers mate
    Here’s hoping that is the cause of the noise, nice and simple.
  5. The Following User Says Thank You to Yendor For This Useful Post:
    jack (8th April 2017)
  6. #13
    Feb 2012
    Camden, NSW
    If you have rear AirCon, could be solenoids related to the gas side of that and the associated bubbling is the refrigerant.
  7. The Following User Says Thank You to Turtle_au For This Useful Post:
    jack (9th April 2017)
  8. #14
    Ballarat Area
    25 Post(s)
    It's not the AirCon turtle, I think I may have misled people by mentioning 'bubbling type noise', that was the easiest way to describe it. It's definitely a relay rapidly switching.
    Looks like its resolved after unplugging the USB charger, but as it was intermittent I won't count my chickens yet.
    Will let it go for a while yet.
    Jack
  9. The Following User Says Thank You to jack For This Useful Post:
    Hodge (9th April 2017)
  10. #15
    Ballarat Area
    25 Post(s)
    I'm going to call this resolved, thanks Rod (@Yendor)
    Jack
  11. #16
    175 Post(s)
    So just curious was it a relay in the end?
    Just good to know for the future.
    Ballarat Area
    25 Post(s)
    Yeap Hodge, it was the relay. I misled people by mentioning a 'bubbling noise' for lack of a better way to describe it. Like Yendor said, the relay wasn't faulty.
    Jack
  13. The Following User Says Thank You to jack For This Useful Post:
    Hodge (13th April 2017)
  14. #18
    175 Post(s)
    Thanks for clarifying...
    Always good to know for future​ reference.
  15. The Following User Says Thank You to Hodge For This Useful Post:
    jack (13th April 2017)
