Results 1 to 5 of 5
Thread: For Sale in WA - DX grunt - 2005 - 4.2 TDi ute with pod
    WA Wheatbelt
    23 Post(s)
    Item for sale: 2005, 4.2 TDi ute with pod- Ex Telstra
    Price: $30,000 firm
    Condition: Reasonable
    Details:
    At the front ……….
     Warn winch (CE XD9000) with all original Operator’s Manual, Replacement Parts List, Installation Instructions and hand controller
     2 x light bars totalling 520 watts
     Harris Hardcase front diff protector
     2 x recovery points
     LED headlights
     Brand new radiator, thermostat and gasket fitted 21/09/16
     Brand new radiator fan fitted 02/10/15
     New starter motor fitted 07/09/16
     GVM 2” lift kit – 3900kg (coil front, leaf rear) with compliance plate fitted 22/03/16
     Both Tie Rod Ends and Steering Dampener replaced 09/06/15
     Front Swivel Housing and axle seals replaced 26/05/15
     Both gas struts on pod replaced 08/06/15
     Codan 9350 Auto tune base with whip aerial and ‘Knock Down’ base
     Bushranger under bonnet shower unit – fitted 06/05/16
    In the cab ……….
     Child restraint anchor point – with compliance plate
     Dash cams – front and rear
     Reversing cameras display
     Centre roof console with storage, 2 x map reading lights and 2 x USB charging ports
     HF Codan NGT AR radio with radio telephone facilities (currently operational with VKS737 and HF Tel), black whip aerial
     1 x UHF and 1 x HF AM, CB radios
     3 seats – all have been re-foamed and re-covered
     Floor mats
     Switch panel that activates lights, DVD, oven
     Original Patrol Owner’s Manual
    In the pod ……….
     Air vents
     Shelf
     1000w inverter (hard wired)
     DVD player – can get extra sound through your radio
     Travel Buddy - 12v marine oven (2014)
     12v WAECO mounted kettle
     8lt hot/cold water storage
     Interior LED lights (activated by 3 switches)
     2 x 45lt ‘BOAB’ brand fresh water tanks with 2 x electric water pumps
     Smoke alarm
     Security screens on both windows
     Behive pattern, thick, hard rubber mats
     Tie down points
     1 x Anderson plug
     2 x 12v ‘cigarette lighter’ type plugs
     2 x 8amp continuous plugs
    On the outside ……….
     Roof mounted, 12v Sand Flag (illumination switch in cab)
     Roof mounted exterior lighting (6 x LED, 48w Flood beam square lights - 2 each side and 2 at rear – illumination switch in cab) 2016
     Roof mounted 2 x 120w BP solar panels with STECA PR 2020 solar controller
     2 x PVC rubbish bags that fit over rear spare wheels
     30lt fresh water storage
     Ventilated storage compartment containing 3rd battery
     Recovery gear/storage compartments underneath pod (left hand compartment goes full length – right hand goes about half way down due to 75lt aux diesel tank)
     Rear recovery point
     External mobile phone aerial
     Reversing beeper and light - 2015
     2 x brand new spare KO2’s, BFG AT (both have 11mm tread) mounted on back of vehicle
     Tyres on vehicle have approx. 7mm of tread
     6 Sunraysia Rims (2016/2017)
     Tow bar
     2 x diesel fuel tanks (main 90lts aux 75lts – approx.)
     2 x rear steps
    Under the bonnet
     Stock 4.2 TDi engine
    2 x batteries – installed 2017 (3 in total)
     Hot water shower kit purchased 01/02/16
     150amp circuit breaker – manual reset
    Brand new Master Brake Cylinder fitted 17/05/19
     Annex – Affixes to purpose built bracket on left hand side roof of vehicle, and is about 3m x 3m, affixed to the ground using corner guy ropes and tent pegs. The first 1m is made of PVC for showering (with 2 x vents) and the main area is made of heavy duty canvas consisting of one room with a door and window with heavy duty mesh. A skirt has been made up and affixes to the left hand side of the pod.
     Awning – the 5m x 3m awning is made up of heavy duty canvass and goes across the rear of the vehicle and the annex.
    Spares: TBA
    Most receipts have been kept for work done on vehicle since purchased.
    The cab and bonnet do need a paint job.
    Registration plates will be changed to normal number plates, prior to sale
    Is having/has had 350,000km service on Fri 17/05/19
    Location: Merredin WA (half way between Perth and Kalgoorlie)
    Contact: Ross 0408 857 552
    Comments: Engine is stock standard and vehicle is having a 350,000km service on Friday 17/05/19. I'm only selling because I have started my own business and drive it to keep it ticking over and doing tip runs.
    PHOTOS: I'm having issues with pics, so here's the link to my 'Member's Ride'. Please start at the last page and work backwards. Some pics are old. Recovery gear not included.
    http://www.nissanpatrol.com.au/forum...+.....in+flesh
    Regards.
    Ross
  2. The Following User Says Thank You to DX grunt For This Useful Post:
    katwoman (14th May 2019)
    WA Wheatbelt
    23 Post(s)
    Added to the list is a brand new Master Brake Cylinder to be fitted on 17/05/2019.
    Feb 2011
    Shed
    45 Post(s)
    And never been off road
    WA Wheatbelt
    23 Post(s)
    I can almost honestly say in the 8.75 years I've owned it, it's been on the beach twice, a decent sandy track once, and heaps of gravel roads and some short distance sandy tracks, and as most of you know, heaps of bitumen
  7. The Following 4 Users Say Thank You to DX grunt For This Useful Post:
    growler2058 (14th May 2019), MB (14th May 2019), Plasnart (14th May 2019), rusty_nail (15th May 2019)
  8. #5
    472 Post(s)
    Show and shine ute competition winner at least twice also if I remember correctly posts on here too Rossco? Worth putting up those pictures of your top winning setup, super comfy looking......Ladies
  9. The Following User Says Thank You to MB For This Useful Post:
    DX grunt (14th May 2019)
