Results 1 to 5 of 5
Thread: 95 Nq Gq Ute
    Apr 2017
    Cairns, Queensland
    95 Nq Gq Ute
    Hi Crew,
    I'm new to this forum and thread stuff, Just thought I'd share a bit of progress with my ute, I picked it up for a steal, it was sitting in a mates front yard for almost two years. Injectors were out the whole time it sat in the yard.
    After a visit to Cairns Diesel Services withe the parts that came with the injectors.
    4hrs later and a carton of corona sweetener for the workshop lads to have Friday drinks, I find out old mate I brought the ute from supplied me with genuine Nissan Parts. Which meant cheaper refurbishment cost.
    So I go to install the injectors only to discover the injector ports hadn't been plugged the whole time. After a bit of mucking around with a vacuum cleaner , and a scribe and some rags n wd 40 threads cleaned up and the injectors went in ok we flushed the lines using Carby clean . Then I bleed up the injectors letting excess diesel clean out anything left in the lines.
    Couple cold cranks and she's now alive. Little bit rough running. But running none the less
    Once I figure out how to post a video I'll post it up.
    Now to look aft the other bits n piece so I can put her over the pits
  2. The Following User Says Thank You to ShakeyShake81 For This Useful Post:
    MB TD42 (28th June 2018)
    Apr 2017
    Cairns, Queensland
    So I went to put sway bars back on and found that the retaining clamps are missing.
    Any ideas or suggestions for replacements I'm pretty sure the ute has 2" lift.
    473 Post(s)
    G'day again Shakey, try this link mate. http://patrolapart.com.au/category/sway-bar-links The search function is playing up so maybe worth an 8:00am phone call AEDT mate!
  6. The Following 2 Users Say Thank You to MB For This Useful Post:
    dom14 (7th April 2017), ShakeyShake81 (7th April 2017)
  7. #4
    473 Post(s)
    Make sure you check your Swaybar D Bracket bolt tensions more regularly than I do folks :-) Bent the bracket good and proper on Sunday up an easy track.
  8. #5
    581 Post(s)
    Perfect for the school drop off Yarra Glen hairpins adventures!
  9. The Following 2 Users Say Thank You to AB For This Useful Post:
    MB (28th June 2018), Rossco (28th June 2018)
