4th April 2017, 09:46 PM
Trailer plug and reverse sensors. How do i disable when the trailer is on?
Hi, when I bought the GU it had the factory reverse sensors and the factory round Nissan tow plug with only 6 wires.
I still have the reverse sensors and have wired the round Nissan plug wires to the standard 7 pin flat plug I had kicking around.
The flat 7 pin was from a Holden with reverse sensors so it also has extra wire "sockets" for reverse sensor wires. This disconnects them when the flap is up.
I cant seem to find any wires on the Nissan tow harness to use to isolate the reverse sensors when you have the trailer on.
Am I missing something or is there a way to wire them to turn the reverse sensors off when the trailer is connected?
The VE commodore I have was a plug an play affair. so I'm not sure what to do with the Nissan.
The current line up on the 7 pin plug I am using is:
Parking Aid Earth - No wire at the moment
Signal Right - Green
Tail Lamp - Brown
Aux/reverse - No wire at the moment
Earth - Thick White
Service Brake - Blue
Stop Lamp - Red
Signal Left - Yellow
Park Aid Ground - No wire at the moment
I need to use the parking aid earth and ground I think but am unsure how to cut them in.
Everything works correctly I just have a continual beep when in reverse due to the trailer being there.
Any help appreciated. Thanks
4th April 2017 09:46 PM
5th April 2017, 08:28 AM
little white plug to be disconecter behind l/h light at rear
if you cant find it put in reverse and follow the sound of beeper behind this light
OH LEATHER IS NICE
5th April 2017, 10:30 AM
Isnt the beeper under the steering coloum ??
6th April 2017, 05:31 AM
your probably right threedogs my mates 2010 i had just done this for him
this ones a 2013
OH LEATHER IS NICE
6th April 2017, 09:15 AM
Missing in Action
Shag
Tail Lamp - Brown
Earth - Thick White
Stop Lamp - Red
Found this on the Narva website, might help you out.
Disconnect the earth from Reversing sensor & run to the input side(next to No. 1 pin). The plug then becomes the earth for the sensor.
The Following User Says Thank You to VK2FMIA For This Useful Post:
6th April 2017, 10:04 PM
VK2FMIA
That's the flat plug I've got. That looks like the info I needed to cheers
6th April 2017, 10:08 PM
Thanks guys. I've got the installation instructions from the dealer, they were kind enough to print off a copy. The brain is behind the LH tail light and the buzzer/beeper is behind the black vent on the left in the cargo area.
VK is onto it though, I think I can work it out now. A nice job for Saturday. It's been pissing me off so it will be a good job sorted.
2013 GU 3.0 CRD.
