Results 1 to 4 of 4
Thread: Fog Light Wiring
    Jul 2017
    Cockatoo, Vic
    Lightbulb Fog Light Wiring
    Hi, I was hoping someone would be able to help me with a clear wiring diagram to be allow me to install my Narva fog lights I've recently purchased.
    I need to know how to wire everything into the relay and into my switch (switch is a Narva 63027BL) which wires go to which pins etc.
    Any advice or help will be much appreciated.
    If you google that part number you will get a wiring pin diagram for it in the first link
    http://www.narva.com.au/products/det...s-popup-layout
    Is this the switch you want to run your fog and spot lights off? Its a pretty basic 4 pin switch and you can go wrong. Just remember that it is a Switch (control circuit) and not the supply circuit. that switch will switch a relay that is the supply circuit. It can switch multiple relays at once.
    Jul 2017
    Cockatoo, Vic
    Yeah that's the switch, but the fog light diagram doesn't show me how to wire it so I can use the switch's LED, unless the LED comes on with just the power and earth?
    Power - connect 12 Volts to power the accessory/load and the internal LED
    ACC - connect the Load or Relay to ACC (in this case the fog lamp relay)
    Ground - is for the internal LED only
    The internal LED in that switch uses the 'ground' terminal IE when you throw the switch the LED sees ground and illuminates.
    If you don't connect ground the LED won't work but the switch will still operate the relay or load
