Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: New trailer advice
    New trailer advice
    Hey guys,
    Just after a little bit of advice in buying a new trailer. I am buying an 8x5 tandem trailer with a cage, it will be used for firewood and that's about it.
    I have two choices at the moment, same price but some slight differences.
    Option 1: http://galvanisedtrailerco.com.au/tr...andem-trailer/
    40mm axles
    50mm x 50mm x 2.5mm chassis
    330mm cross rail spacing underneath
    Car tyres
    Option 2: http://www.balancetrailers.com.au/pr...bt85t/bt85twb/
    45mm axles
    70mm x 50mm x 3mm chassis
    430mm cross rail spacing underneath
    Light truck tyres
    Option 2 seems like a stronger trailer to me but curious if the larger spacing between supports will be a big deal?
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Whats the floor sheet thickness of the 2.
    Sent from my SM-G800Y using Tapatalk
    Both 2.5mm
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Option a for sure then.
    Its cross members you want for strength.
    Option B Being 100mm wider but still the same floor thickness you'll be buckling and bowing the floor in no time with wood going in and out..
    You can easily add a small underside cord or truss to the 50x50 draw bar if its a bit lite, but its major work to add cross rails..
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Just for wood I think if price was the same I'd go option 2 , heavier chassis , the 6x4 I use the is rusted so bad the only thing it's got going for it is the heavier section underneath .
    But it is probably 30 plus years old and had dogs pissing all over it for years .
    Pretty sure the paint is structural on this one .
  7. The Following User Says Thank You to GQtdauto For This Useful Post:
    Winnie (3rd April 2017)
  8. #6
    330 Post(s)
    ghee that second trailer looks like a beast though. the chassis will be way stronger on the second one as will be the axles and everything else. I agree the spacing is not ideal though but everything else looks very heavy duty for a domestic trailer. I think either will see you for many years to come mate.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #7
    Expert billyj's Avatar
    gordon
    3 Post(s)
    either will do the job fine for a long time without seeing both in the flesh its hard to say which way id go. personally ive had 2 trailers built by victorian trailers in thomastown one a 8x5 tandem tradie trailer thats copped a flogging for nearly 10 years on rough civil construction sites and aa 7x5 off road custom built to my specs. can also say i loke the look of the trailers coming out of hoppers crossing trailers, while there picking up some parts to rebuild my boat trailer over newyears i was given a tour of the plant and everything is very well made
    the one thing i will say is get electric brakes. or if you wont go electric get hyd drums instead of cable disk, the disk setup is just harder to adjust right, personally ive got both, hyd drums on my work 8x5 tradies trailer and disc on my 1.8t boat, and id take the drums any day over the discs
    gone to the dark side 2017 vdj 79 dc
  11. #8
    Feb 2012
    Camden, NSW
    Do they give an option for stud pattern? Always handy to have stud pattern match the tow vehicle.
    Sent from my SM-T355Y using Tapatalk
  12. #9
    The master farter
    mudski's Avatar
    462 Post(s)
    Either look to me to be fine, but not even looking at the links and just going by the specs you posted I picked option 2.
  13. #10
    Cheers guys. I've seen both trailers in the flesh and the 2nd one I posted looks to have better welds as well.
  14. The Following User Says Thank You to Winnie For This Useful Post:
    mudski (3rd April 2017)
