Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: newbies trapped in Bundaberg
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    581 Post(s)
    Welcome to the forum mate and feel free to ask any questions.
  4. #13
    175 Post(s)
    Welcome to the forum.
    For a second I thought, nissannewby was trapped up there after I read the title.
  5. The Following User Says Thank You to Hodge For This Useful Post:
    Clunk (3rd April 2017)
  6. #14
    Apr 2017
    Thanks for the welcome guys. Yes, ours is TB42E so does have it. It runs on gas as well and after searching around a bit I've found that this tends to happen on dual fuels of this model.
    We were able to check it by seeing if the car would idle with the sensor unplugged, which it did. Wish it could just run without it though!
    I didn't think about facebook, thanks Clunk!
  7. #15
    Jan 2015
    Canberra
    The workshop manual (downloadable from this site) has the procedure for testing the air flow meter but the best way is to find a workshop with a Nissan Consult handset (or cable + software). This will plug in and tell you immediately if there is a problem with the meter and other sensors. I have found the air flow meter to be surprisingly reliable, every time I have suspected a dodgy AFM it turned out to be something different. Maybe check the basics like fuel pump (common failure point) and filter, crank angle sensor, coil, etc.
    WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
  8. #16
    Dont you check the MAF with a multi meter to see what OHM's it pulls at different revs.
    Is it possible to clean your MAF sensor, easy job on the ZD30's
  9. #17
    Easy enough to remove, but as JME said, these air flow meters are extremely reliable...... I'm definitely no expert though
  10. #18
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    G'day Debs,
    As MB says, search under MAF sensor.
    Then, sorry to look like a complete dope but,,,,you HAVE sprayed the MAF sensor with the appropriate spray, haven't you?
    Assume you've been real careful drawing it out of the fixing with no fingers in the wrong places etc. etc..
    It is, in my experience, one of those fiddly fittings which never goes wrong or is for no obvious reason totally cactus. Bugga!!
    God luck,
    Col.
