Page 1 of 10 123 ... LastLast
Results 1 to 10 of 98
Thread: Getting hot after Dawes needle and 3"
    Feb 2011
    Shed
    45 Post(s)
    Wow my water temps are HIGH like 122c high climbing up the hills. Only started since fitting the 3" zorst Dawes and needle @mudski any ideas??
    175 Post(s)
    What's your EGT's doing ? Where are they at when that happens?
    also what boost are you getting ??
    462 Post(s)
    Hey mate. We need to know what your max boost is and what your boost is at 100k's. Also an idea of EGT's too mate. If anything I would say your spool up is too slow, causing slight over fueling which may bring on higher than usual coolant temps. You manual or auto? If manual what gear were you in?
    Feb 2011
    Shed
    45 Post(s)
    Haven't got the egt gauge in yet will do that tomorrow. Boost normally 15.5 saw it hit 16.2 going up the hill at the start. Been watching it at 100ks and it's around 10-12 it fluctuates a bit.
    Edit: it's an auto
    Another quick question have you blocked the EGR yet ????
  8. #7
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Shouldn't really have fitted it without an EGT gauge...
    Try closing the needle valve to speed up the spool rate a bit.
    2003 GU SIII Auto Grenade. All the goodies.
  9. The Following User Says Thank You to Softy For This Useful Post:
    growler2058 (13th March 2017)
  10. #8
    Feb 2011
    Shed
    45 Post(s)
    Yep egr is blocked
  11. The Following User Says Thank You to growler2058 For This Useful Post:
    threedogs (13th March 2017)
  12. #9
    Unafordable
    4 Post(s)
    Firstly, how do you know it is hitting 122°C, factory gauge will not point to that. So Scangauge perhaps? Is it just incorrect gauge setting because at that temp the engine will be cooked for sure.
    Secondly, fitting Dawes and needle valve combo even if you set it wrong (read lower values) should never ever cause engine overheating to such highs full stop. If unplug the vacuum hose from the actuator and go for a drive, the only thing you will notice is lack of power and perhaps EGTs skyrocketing. If anything Dawes and needle valve combo is exposing the issue with cooling system because they makes the system power up and stay up more. In any case this just might be coincidence.
    3" exhaust will not cause overheating for sure.
    To me this sound like either fan not working correctly or radiator is blocked either internally or externally which would affect the engine fan.
    Regards
  13. The Following 2 Users Say Thank You to Rumcajs For This Useful Post:
    growler2058 (13th March 2017), threedogs (13th March 2017)
  14. #10
    Try with the air-con on and fan on two, that will kick in the fan for the condensor
    and maybe eliminate the viscous coupling as the problem
    I was struggling to see how a 3" system would cause over heating probs
