Results 1 to 6 of 6
Thread: Scangauge II
    Mar 2017
    Panama
    Scangauge II
    Hello im from panama ist any whan are install a scanguege on a patrol 2003 di 4x4, i cant install my, never stops saying "connecting"
    I dont think the Scan-gauge will work on the Di motor.
    I have an ECU-talk and it works a treat and its mounted
    in front of the gauges
    contact peter at
    peter@ecutalk.com.au
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Wont work on a DI you need a ECUTalk like above.
    2003 GU SIII Auto Grenade. All the goodies.
    May 2017
    Hey guys. I have a DI. been hearing ecutalk will read boost on series 4 but does it read it on series 3 08/2004. cheers
  6. #5
    May 2017
    sorry fellas, bombing this thread as it's the only way I've learnt to post so far. Looking into all the NADS mods through old forum searches. HAs anyone learnt to make a computer chip that automatically creates the same effect through ECU for cleaner run and better fuel economy
  7. #6
    The master farter
    mudski's Avatar
    460 Post(s)
    Quote Originally Posted by kaneparker View Post
    Kane I didn't think the ECU talk could read boost at all. Not even on the Series 4. I could be wrong though....
    Edit : You are correct sorry. snippit from the ECU website
    Added Sensors for ZD30
    Injector Control Valve (ICV) %
    Variablenozzle Turbocharger Solenoid Valve %
    Barometer hPa
    Spill Valve Crank Angle
    Boost PSI (some only, e.g. GUIV Patrol)
    Fuel Temp Sensor ºC/ºF
    http://www.ecutalk.com.au/diesel.aspx
