27th March 2017, 12:19 PM
Brakes Problem
Just replaced the master cylinder after 2 mechanics & myself tested the pedal and found that if we keep our foot on the pedal, it will eventually go to the floor.
Well, with a new master cylinder fitted, I have exactly the same problem. Push hard on the brake pedal and leave your foot on it, your foot eventually goes to the floor.
I've got new extended rubber brake lines as I have a 3" lift.
There's no loss of brake fluid.
Is this a Patrol 'thing'? I wouldn't have thought so.
Thanks for any help.
27th March 2017 12:19 PM
27th March 2017, 12:27 PM
Try teflon braided lines they cant expand like rubber will
27th March 2017, 01:15 PM
Yeah, I'm thinking that TD.
27th March 2017, 01:36 PM
How old is brake fluid? Is engine running (vacuum for booster)? Drum or disc brakes? Rear proportioning valve (load sense)?
27th March 2017, 02:05 PM
Fluid is new as all hoses were replaced in the last 6 months. discs all round. Doesn't have rear prop valve.
27th March 2017, 03:26 PM
Bleed / test the LPV. Every mechanic (even brake specialists) miss that.
27th March 2017, 03:51 PM
10G
You can sometime end up damaging the master pump by manual depressing of the brake pedal to bleed the system(pressing it all the way to the bottom), but that usually happens with a used master pump, where the seals are already weaker.
How did you bleed the master pump, etc?
27th March 2017, 08:27 PM
BillsGU
I don't know if the wagons have LPVs?
dom14
I let the mechanic do it.
27th March 2017, 10:34 PM
Its a Patrol thing. I have changed to braided line, new cylinders and rebuilt calipers and it still does it. I wouldn't be concerned about it.
28th March 2017, 08:48 AM
mudski
Bloody hell, that's not too brilliant.
The other week I was travelling home, a guy towing a Dunny door on a trailer got into trouble coming down hill (this is 100kmh both ways, country road), I was going up hill. He fishtailed until the trailer began to steer the car, he crossed both sides of the road and a bit more, I planted my foot on the brakes and the damn pedal just kept going to the floor and I was getting closer and closer to this guy.
Anyway, I'm still here.
