Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: Brakes Problem
  1. #41
    Feb 2012
    Camden, NSW
    Maybe an ABS thing? Not sure on the intricacies of the unit but it does control pressure to wheels, maybe bypasses excess pressure?
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    Quote Originally Posted by Turtle_au View Post
    yeah i agree it might even be a bit of air in the abs unit. or one of the valves/solenoids not closing properly
    check the bleeding procedure for the abs (some cars are picky about this)
  4. #43
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by garett View Post
    yes dom they are the same just different sizes. ( not saying the are interchangeable just they work the same way)
    but i would be surprised if a leaky clutch booster would affect the brake much. unless its a really big leak. never seen one i real life so speculating here.
    Cool, thanx mate. Mine's never had a clutch booster(afaics), so it's a totally new territory for me.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  5. #44
    Expert billyj's Avatar
    gordon
    3 Post(s)
    a leaky booster makes the pedal rock hard not soft, a soft sinking pedal is air or a leak no ifs buts or maybes
    gone to the dark side 2017 vdj 79 dc
  6. The Following User Says Thank You to billyj For This Useful Post:
    dom14 (6th April 2017)
  7. #45
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Quote Originally Posted by billyj View Post
    I agree. With mine the air was in the LPV and could not be bled out due to the piston not working correctly. The LPV is the highest point in the rear brake system and all air and moisture seems to accumulate there, especially if it is never bled - which seems to be the case in most Patrols.
