23rd March 2017, 11:30 AM
Winch Cradle
Has anyone installed the winch cradle from http://www.nissangupatrol.com/produc...alloy-bullbar/ ?
I was wondering how you accessed the winch clutch lever as it seems to be inaccessible in this set up.
23rd March 2017 11:30 AM
23rd March 2017, 11:45 AM
Can you turn the gearbox 90 degrees for ease of access
25th March 2017, 08:49 AM
Patrol Goddess
I had that on my first GU. Had to mount it upside down. Access from under the bullbar.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
25th March 2017, 11:59 AM
Good point about rotating the gearbox threedogs.
Katwoman is that what you mean by mounting it upside down or did you actually mount the cradle upside down?
The Following User Says Thank You to Mc4by For This Useful Post:
katwoman (26th March 2017)
26th March 2017, 06:37 PM
Patrol Goddess
Mc4by
The winch.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
1st April 2017, 09:32 PM
You will need to move the gear lever side cover plate on the winch--simply remove studs and turn 180 degrees. Then per katwoman, turn the winch over. That is because cable exits wrong location if you mount it "right way up" Warn advises you need to make a new drain slot, as it is now on top. Works on mine.
2nd April 2017, 05:01 PM
I have skills, but not mechanical ones.
I understand rotating the clutch to access from below.
However if I turn the winch upside down wouldn't that put the clutch lever back where it was before I rotated it? So I really wouldn't need to rotate it at all.
How do you mount the winch upside down? Aren't there mounting points that you bolt to the cradle? If I turned it upside down I would have to bolt it to the bottom of the cradle. I need to go stand next to a winch and check it out.
Take a deep breath before you reply please
2nd April 2017, 08:25 PM
#8
This thread of mine might help in regards to mounting and also rotating the clutch lever.
Tigerz11 Dominator in GU series IV Std Steel bullbar
https://r.tapatalk.com/shareLink?sha...0&share_type=t
2007 GU ST-S 4.8 Patrol.
40mm heavy duty springs, Dual batteries,
140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
The Following User Says Thank You to Skitzyrex For This Useful Post:
2nd April 2017, 10:41 PM
#9
That makes it clear. Rotate it left to right rather than top to bottom.
I just needed some pics. Thanks again.
