Results 1 to 3 of 3
Thread: Fuel Tank Drains GU 11
    May 2016
    8 Post(s)
    hi all still working on the white submarine ! is there and fuel drains in the bottom of the fuel tanks ? I cant see any . I might be looking in the wrong place .
    Aug 2011
    River Heads Q
    4 Post(s)
    Don't think so as dealer had to remove rear tank to drain and clean after I got a bad batch of fuel many years ago.
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    most newer cars no longer have drains on the fuel tank. you would struggle to find one with a drain. if the tanks is plastic it might have a pierce here spot on it. but you still need to take it out.
