Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Dash light comes on when I I put foot on brake(sometime)
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    i know astra's if you put the wrong globe in the tail light leave the parkers on you can't turn the engine off...
  2. The Following User Says Thank You to garett For This Useful Post:
    dom14 (19th March 2017)
    Legendary dom14's Avatar
    38 Post(s)
    I agree with Mudnut, check the trailer plug first.
    By the looks of it, trailer plug is ok. I couldn't notice any degradation of the wires/connectors or any short circuits.
    But, I noticed both front parking light globes are blown. It's the globes.
    Can it be the reason for strange behaviour?
    I'll have to replace the globes tomorrow.
    Thanx mate.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  5. #13
    Check all of the earth wires to the light assemblies and where the bulb meets the holders. The current will flow via the easiest path so that could be the cause.
  6. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (20th March 2017)
  7. #14
    Patrol Guru
    Jul 2014
    6 Post(s)
    I'd be leaning towards an earth issue also. I had a similarish issue, indicator lights coming in with the brakes, brakes coming on with the indicators. Earths had degraded. New earths and better than ever.
  8. The Following User Says Thank You to Throbbinhood For This Useful Post:
  9. #15
    Is the patrol on the road or just a project of yours???
    I was lucky enough to see the original film at the Drive-in years ago lol
  10. #16
    38 Post(s)
    Both, I reckon.
    That would've been in early seventies. I'm beginning to imagine the reason you watched the movie at the drive-in theatre.
    Cheetah Outreach
  11. The Following User Says Thank You to dom14 For This Useful Post:
    threedogs (21st March 2017)
  12. #17
    38 Post(s)
    It was the stupid brake light globe.
    The two filaments of the globe were internally fused on one end(right hand side brake light globe), hence the reason for bizarre behaviour of the dash lights. The rain/water got nothing to do with it, other than possible moisture/humidity causing it to fuse permanently(or semi permanently).
    Cheetah Outreach
  13. #18
    Good find, Dom.
  14. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (21st March 2017)
  15. #19
    38 Post(s)
    Good find, Dom.
    Here is the real problem.
    The small filament was sort of "growing" a pointy "tentacle" and joining the bigger one right next to it, and eventually managed to fuse the two filaments. Since the braking and rear parking light filaments are fused on the same globe, no doubt why it was turning on the dash lights when the brake is pressed, 'cos parking lights and dash lights share the same power line.
    Cheetah Outreach
  16. The Following User Says Thank You to dom14 For This Useful Post:
    mudnut (22nd March 2017)
