Results 21 to 30 of 34
Thread: No power under load while on petrol
  1. #21
    49 Post(s)
    Quote Originally Posted by Mike02Ti View Post
    Not necessarily. If the 02 sensors functioning somewhat they may not throw a code.
    Mine on my 48 are buggered. Using about 30l/100km.
    No code or engine light but all over the place when i read them with NDS II. Runs great on gas though.
    Also check the cat converter and see if its blocked
    Was speaking to a mechanic the other day. And he said that the MAF sensor has nothing to do with the engine while running on gas wonder if the O2 sensors are the same. Exhaust is as old as the car so may have a good chance that the catalytic converter is blocked but wouldn't that also affect the performance while running on gas.
  2. The Following User Says Thank You to jay see For This Useful Post:
    Mike02Ti (10th March 2017)
    49 Post(s)
    Quote Originally Posted by Bob View Post
    Yes it is
    @jay see
    OK and your using the same unit that I posted the pic of?
    Might need to find some time to travel up your way.
  5. #23
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    I know my gas system takes no readings from the factory o2 sensors. It has its own sensor welded in and wired to the gas control unit sitting in my engine bay.
    And he is right about the MAF sensor too.
    Yeah you would probably see a performance drop on gas too if the cat was stuffed. How much i dont know. Especially if you are used to it over time.
    2002 GUIII Ti 4.8
    Details here
  6. The Following User Says Thank You to Mike02Ti For This Useful Post:
    jay see (10th March 2017)
  7. #24
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Yes except the display is on the Laptop and not the Rectangle one shown
    http://www.ecutalk.com/ecutalk.aspx
    @jay see
  8. The Following User Says Thank You to Bob For This Useful Post:
  9. #25
    OOI what shape is your dianostic port under the steering wheel
  10. #26
    Oct 2010
    Pakenham
    47 Post(s)
    see attached
    http://pinoutguide.com/CarElectronic...e_pinout.shtml
  11. The Following User Says Thank You to Bob For This Useful Post:
    threedogs (11th March 2017)
  12. #27
    49 Post(s)
    Same.
    @Mike02Ti
    I had a look at the 02 sensor and it has two wires coming out of the plug, one goes to the gas system. Looks like it a similar set up as yours. I think I might be able to get my hands on a scan tool of some sort, just need to find out if it will connect to my plug.
    Edit
    No good with the scan tool. Only does odb2
  13. #28
    Jun 2016
    Rockingham WA
    4 Post(s)
    @jay see if you download NDS I for android or for windows you will be able to check out codes etc you should also be able to check out the readings from the o2 sensor as well. I have been using ndsII for a while for checking stuff and it's great to use. The android app will only read ECU . The windows version reads ECU and TCM
    Only thing you will need is a consult I plug either usb for windows or bluetooth for android.
    Maybe a member around you has one to borrow?
    Alternatively you can get an adapter from consult to obdii style as well
    2002 GUIII Ti 4.8
    Details here
  14. #29
    49 Post(s)
    I did try a while ago with a Bluetooth obd2 and adapter cable. Worked well on my wifes ve, but did nothing on the patrol.
    Will need to look at it again.
  15. #30
    49 Post(s)
    Something like this.
    Look at this on eBay http://www.ebay.com.au/itm/272583885496
    Never mind.
    I've had a look at the nds site. 👍
