7th March 2017, 07:18 PM
Replacing rotors - what grease for front wheel manual hubs and brake caliper slides?
Hi
I'm replacing the front hubs and at least one sides bearings. I have Castrol HTB 2 for the bearings but I read somewhere the manual hub should be cleaned and lubed with 'general grease'; is this true? I assumed HTB as its all some same location. Further; what is the recommended lubricant for the sliding frame/bolts of the brake calipers?
7th March 2017 07:18 PM
8th March 2017, 10:21 AM
have a search for @MudRunnerTD DIY thread on wheel bearing replacement
Its very comprehensive and well worth seeking out
MudRunnerTD (8th March 2017)
8th March 2017, 12:27 PM
Breadmaker Shaker
Jonesy_sa
Hi
threedogs
have a search for @
It's here:
http://www.nissanpatrol.com.au/forum...Rebuild-Thread
The Following 2 Users Say Thank You to Plasnart For This Useful Post:
MudRunnerTD (8th March 2017), threedogs (8th March 2017)
9th March 2017, 09:51 PM
Thank you for the great link however I could not see an answer to my two main question?
What grease for the manual hub gears and what grease for the sliding component of the brake caliper?
If I missed it which post number was this detail covered?
9th March 2017, 10:30 PM
Hardcore
Manual hub gears I'd use a waterproof grease but it really only needs a slight coating don't glob it in
The caliper slides use caliper grease though I've heard people use high temp anti seize
Sent from my E6653 using Tapatalk
Lucus30's 1999 GU ST TB45E
17th April 2017, 05:56 PM
HTB for everything in the hub
Caliper grease for the slides (expensive) but worth it
