28th February 2017, 10:29 PM
What suspension bushes do I get????
My gq has a 5" lift do I need to get any special suspension bushes? Need them asap as the ones I've got are flogged to all buggery!!!!
28th February 2017 10:29 PM
28th February 2017, 10:37 PM
5" lift? That's pretty high.
Not sure about special bushes for a lift that high. Somebody who knows will post an answer.
28th February 2017, 10:43 PM
1st March 2017, 08:28 AM
Which bushes are you talking about? If radius arm bushes, do you have drop boxes?
Most go with standard rubber bushes.
Andrew
GU3 Patrol, TB48, 33" muddies. front E-locker. 4.11 diff gears. 2.2 metre steel rack. Awning. Steel rear bar. Safari Snorkel. ARB side steps and brush rails. ARB Deluxe bull bar. Winch. 2" lift.
1st March 2017, 09:40 AM
I want to change all the bushes up front and Yea it has drop boxes, so I can just buy a normal bushing set and will be right?
1st March 2017, 09:44 AM
Best to stick to the standard Nissan rubber bushes where you can.
If you have the right dropboxes to suit the lift, then everything will be standard.
The Poly bushes, from experience, don't last as long as the Standard Rubber Bushes, so I tend to veer away from these.
1st March 2017, 11:12 AM
X 3 stick to OE rubber the poly tend to flog out quickly
1st March 2017, 11:39 AM
Rubber it is cheers for your help
